> My fog lights are acting foggy, Like fog, my fog lights don't come on until they get warm. ???
tumamilhem
post Apr 19 2015, 05:48 AM
LUFTBRIGADE
Anybody have this issue or know how to correct it?
My fog lights do come on. However, I have to drive for about 5-10 minutes before they come on. It's like something has to heat up the connection before they will come on.
I thought there may be a bad wire connection. But if that were the case, they would come on intermittently and at random (when I first start the car, maybe go off at some point, etc.). But they always do come on and stay on, just after the car warms up.
Any idea why this is happening?
Tom
post Apr 21 2015, 12:30 PM
George N. sure. I have never run into one of these that stick, however that doesn't mean that one couldn't. Could also have some kind of debris inside the can that would get between a contact and bumps could dislodge it, but these are not likely as the cans are sealed.
I do believe all of the Black round relays are the same. 911's have a red one, don't know about them.
Tom
tumamilhem   My fog lights are acting foggy   Apr 19 2015, 05:48 AM
Steve Snyder   Tommy, It sounds like your relay is failing. The ...   Apr 19 2015, 08:13 AM
mepstein   Make sure to have this thread deleated after you g...   Apr 19 2015, 08:44 AM
billh1963   Make sure to have this thread deleated after you ...   Apr 21 2015, 12:13 PM
tumamilhem   Make sure to have this thread deleated after you...   Apr 21 2015, 01:46 PM
tumamilhem   Tommy, It sounds like your relay is failing. The...   Apr 19 2015, 08:44 AM
Mike Bellis   Relay or crusty connection or ground. Incandesce...   Apr 19 2015, 10:12 AM
Tom   Yep, as the relays age, they start getting a built...   Apr 19 2015, 03:22 PM
tumamilhem   Yep, as the relays age, they start getting a buil...   Apr 20 2015, 11:17 AM
Steve Snyder   Tommy, There is no solenoid in your fog light cir...   Apr 20 2015, 05:21 PM
914_teener   Ah.......I disagree with the last post. It does pe...   Apr 20 2015, 06:51 PM
Steve Snyder   Ah.......I disagree with the last post. It does p...   Apr 20 2015, 07:30 PM
Tom   The first line simply states that relays do not de...   Apr 21 2015, 04:55 AM
ThePaintedMan   The first line simply states that relays do not d...   Apr 21 2015, 06:50 AM
tumamilhem   The first line simply states that relays do not ...   Apr 21 2015, 01:41 PM
tumamilhem   The first line simply states that relays do not d...   Apr 21 2015, 01:32 PM
tumamilhem   Will check the connections. Am I right in thinking...   Apr 21 2015, 10:00 AM
Tom   George N. sure. I have never run into one of thes...   Apr 21 2015, 12:30 PM
Dave_Darling   I do believe all of the Black round relays are the...   Apr 21 2015, 03:04 PM
tumamilhem   I do believe all of the Black round relays are th...   Apr 21 2015, 03:06 PM
Mike Bellis   Most likely the lamp sockets and terminals are cor...   Apr 21 2015, 07:52 PM
- Lo-Fi Version Time is now: 4th July 2025 - 01:05 AM
