> My fog lights are acting foggy, Like fog, my fog lights don't come on until they get warm. ???
tumamilhem
post Apr 19 2015, 05:48 AM
LUFTBRIGADE
Anybody have this issue or know how to correct it?
My fog lights do come on. However, I have to drive for about 5-10 minutes before they come on. It's like something has to heat up the connection before they will come on.
I thought there may be a bad wire connection. But if that were the case, they would come on intermittently and at random (when I first start the car, maybe go off at some point, etc.). But they always do come on and stay on, just after the car warms up.
Any idea why this is happening?
Tom
post Apr 21 2015, 04:55 AM
The first line simply states that relays do not develop a time delay. Those who think they do are just mistaken. Relays are a simple electro magnetic device that changes a set of contacts from open to closed or closed to open. When the relay fails, it will not operate now or later. Having worked in the electrical/electronics field since 1966, I have never seen a relay develop a time delay. If power is applied and it does not work, it is defective and needs replacing.
If yours is coming on later, that is telling me that there is a bad connection somewhere in that circuit that is keeping the power from the relay until you drive the car for a while. I had one similar and when driving and hitting a bump the wipers and associated electrical devices would quit working. Drove me to drink trying to find out what was wrong. J-13, the fresh air blower relay, was intermittent due to weak contact in the socket for that relay. Cleaning the sockets and the relay prong, and spreading the prongs slightly cured that problem.
The thread I put together was in response to a member who had a melting socket issue and it was being caused by heat build-up due to resistive( bad ) contact of the relay prongs in the socket. Heat is the enemy of electrical circuits. After replacing the socket all worked OK.
Clean and tight electrical connections are a must for good performance.
If you don't have a working knowledge of electricity, I can't explain it to you any better than that.
Hope this explains things a bit better.
Tom
ThePaintedMan
post Apr 21 2015, 06:50 AM
QUOTE(Tom @ Apr 21 2015, 06:55 AM) *
But along the lines of a bad connection/ground that eventually "awakens" while driving, you could also suspect that the relay itself is sticking. Eventually going over a bump just right causes it to unstick.
The cure is the same though, clean all connections, sockets, etc first. If the problem still persists, try swapping relays, right Tom?
tumamilhem
post Apr 21 2015, 01:41 PM
LUFTBRIGADE
QUOTE(ThePaintedMan @ Apr 21 2015, 08:50 AM) *
The thing is, even if I don't hit any bumps, just smooth driving, it will come on eventually. I've even experimented at a stop light. I look at my lights in the reflection of the car in front of me. My fogs will not be on. I'll turn them on and off and maybe they will come on while sitting there. Or a couple of times I've turned my lights off all the way (headlights) then back on with the fogs and they'll come on. It always seems to be a common factor of how long I'm driving the car.
A couple times I'll let it run in the garage. Fog switch is on but no light. Then after a while, turning the switch on and off (or just leaving it on), they will come on just sitting there idling. So there's no bump to make a physical change in the connection. Very odd.
Anyway, if all these black round relays are the same, I'll just swap on known good working one with the fog one to see if that makes a difference. I'll also clean the connections with some 0000 steel wool and alcohol too.
This may be a similar problem....
My right blinker is also acting up (gauge light, not external). If I turn my left blinker on, the light in the gauge works fine. If I turn my right blinker on, the light will blink twice then go off (actual turn signals still blink, I'm just talking about the light in the gauge). Sometimes, it will come on again at random and blink once then go off. But regularly, it will blink twice when I first turn it on then stop blinking.
I think Carol Anne's in my electrical system. (IMG:style_emoticons/default/blink.gif)
tumamilhem   My fog lights are acting foggy   Apr 19 2015, 05:48 AM
Steve Snyder   Tommy, It sounds like your relay is failing. The ...   Apr 19 2015, 08:13 AM
mepstein   Make sure to have this thread deleated after you g...   Apr 19 2015, 08:44 AM
billh1963   Make sure to have this thread deleated after you ...   Apr 21 2015, 12:13 PM
tumamilhem   Make sure to have this thread deleated after you...   Apr 21 2015, 01:46 PM
tumamilhem   Tommy, It sounds like your relay is failing. The...   Apr 19 2015, 08:44 AM
Mike Bellis   Relay or crusty connection or ground. Incandesce...   Apr 19 2015, 10:12 AM
Tom   Yep, as the relays age, they start getting a built...   Apr 19 2015, 03:22 PM
tumamilhem   Yep, as the relays age, they start getting a buil...   Apr 20 2015, 11:17 AM
Steve Snyder   Tommy, There is no solenoid in your fog light cir...   Apr 20 2015, 05:21 PM
914_teener   Ah.......I disagree with the last post. It does pe...   Apr 20 2015, 06:51 PM
Steve Snyder   Ah.......I disagree with the last post. It does p...   Apr 20 2015, 07:30 PM
Tom   The first line simply states that relays do not de...   Apr 21 2015, 04:55 AM
ThePaintedMan   The first line simply states that relays do not d...   Apr 21 2015, 06:50 AM
tumamilhem   The first line simply states that relays do not ...   Apr 21 2015, 01:41 PM
tumamilhem   The first line simply states that relays do not d...   Apr 21 2015, 01:32 PM
tumamilhem   Will check the connections. Am I right in thinking...   Apr 21 2015, 10:00 AM
Tom   George N. sure. I have never run into one of thes...   Apr 21 2015, 12:30 PM
Dave_Darling   I do believe all of the Black round relays are the...   Apr 21 2015, 03:04 PM
tumamilhem   I do believe all of the Black round relays are th...   Apr 21 2015, 03:06 PM
Mike Bellis   Most likely the lamp sockets and terminals are cor...   Apr 21 2015, 07:52 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 11:57 PM
