thieuster |
Member ![]() ![]() Group: Members Posts: 447 Joined: 31-January 15 From: 275 mls NW from Stuttgart. Member No.: 18,384 Region Association: Europe ![]() |
Perhaps is can be done faster, but I wanted to do it properly. And with the help of the Pelican website's 'how to', the job went smoothly.
The clutch cable showed worryingly signs of wear, so I will have to replace that as well. Hell hole etc is solid as a rock. I will remove the isolation blanket at a later stage, but things look good at first sight. The engine... well... let's say that the tins carried at least 7 lbs of sand! No signs of oil contaminantion. Just sand, sand, sand! The back of the gearbox is covered in sand + oil. I will have to attack that with a steam cleaner and degreaser. Now the engine is out for cleaning and replacement of the pushrod tubes, it's the perfect moment to look at other parts as well: - powder coating the tins, - replace all hoses, - have a look at the clutch - have a look at the alternator - replace the V-belt (see pic...) A DPO (Dumb Previous Owner) must have noticed that the car had earthing problems. All earth wires were bundeled to a bolt with tape and a single wire ran from the bolt to the - side of the battery... Time to put that straight as well! The battery of my telephone was very low, so I was able to take one pic... Says it all, I think... So yeah, taking the engine out took two hours. Cleaning the engine (to start with) will take a lot longer (IMG:http://www.914world.com/bbs2/uploads_offsite/i211.photobucket.com-18384-1430342151.1.jpg) |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
2 hours is an appropriate amount of time for an engine drop. Any faster than that and you're rushing. And I'm a believer in the phrase, Haste makes waste. (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 1st July 2025 - 08:13 AM |
