richardL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None ![]() |
I was trying to fit the new pedal board I have and it won't fit as it keeps binding on the brake pedal. When I played with the pedal I can move it off of the rest towards the master cylinder about 3/4" using one finger. I believe the free play should be closer to 1mm?
Anyhow it seems to me that I should be adjusting the rubber stop forwards to reduce the play - and this would move the rest position of the pedal forwards and reduce the free play and hence also the pedal board to fit in. Is that correct? or am I missing something? OK... How do I do that adjustment? I can't see any way of moving the rubber stop towards the front of the car as it is attached to the bearing tube. Essentially I am trying to stop the spring pushing the pedal up too far, but I can't see how to make that adjustment. I think I have read that the pedal height is adjustable? Hope this is clear, Thanks, Richard |
richardL |
I had thought of a jack but I need to brace it against something to get the force at the right place - any suggestions?
The cluster already has bronze bushings. Most things on this car have been rebuilt sometime in the last 10 years or so. There is no leakage in the MC boot. Richard |
Lo-Fi Version | Time is now: 11th July 2025 - 04:51 PM |
