| DNHunt |
Sep 3 2004, 09:22 PM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I decided to rig up a degree wheel to use in setting up the valve train. It's just a paper 360 degree disk stuck on my trigger wheel with a pointer off 1 of the studs for the cooling shroud. It should be interesting to see where valves open and close.
Dave Attached image(s)
| DNHunt |
Sep 6 2004, 03:28 PM
The adjusters are swivel feet. The one in the picture is an old pointy thing I ground so I could see better. Here's a better picture of the adjusters. Note they are not on center engine front to engine back. A couple are about 3/4 of a mm one way or the other.
Reading the cam at the valve just drove me crazy. I had to keep asking myself how many times did that go around. It turns out the cam has more lift on the intake than the exhaust but a longer duration on the exhaust. The intake ramps up faster so the duration at .050" is almost the same. The rocker shims are thicker on the 1, 2 side than the 3, 4 side. I think I have it right. Dave Attached image(s)
DNHunt Decided to rig up a degree wheel Sep 3 2004, 09:22 PM
DNHunt I think it will make it a little easier to replica... Sep 3 2004, 09:26 PM
d7n7master SOB!!! I want your engine stand!... Sep 3 2004, 10:09 PM
Mueller look'n good Dave :worship:
nice degree whe... Sep 4 2004, 01:22 AM
Tom Perso Have fun with that!!!
Do you have the... Sep 4 2004, 05:35 AM
DNHunt Tom
Mine are some single springs. I have some spr... Sep 4 2004, 06:59 AM
Tom Perso You are all set!!!
Good luck... Wh... Sep 4 2004, 07:44 AM
DNHunt Chromoly Sep 4 2004, 08:32 AM
DNHunt Here's a picture of the trial springs on the v... Sep 4 2004, 08:34 AM
DNHunt I made a little stand for the dial indicator that ... Sep 4 2004, 08:37 AM
DNHunt I've got a rectangular frame that clamps the i... Sep 4 2004, 08:40 AM
DNHunt Well, we managed to get 1 cylinder done. Dad had a... Sep 4 2004, 09:32 PM
DNHunt The idea is to get the adjuster parallel to the va... Sep 4 2004, 09:39 PM
DNHunt A lot of trial and error. Here as good a shot as I... Sep 4 2004, 09:46 PM
swood Dave, how's the vtg going? What adjusters are... Sep 6 2004, 01:07 PM
Jake Raby Dave, looking good! I like your tool for the g... Sep 6 2004, 03:27 PM
Jake Raby Looks great Dave... Thats what its suppose to look... Sep 6 2004, 03:30 PM
DNHunt Here's Gerry torqueing down the rockers to che... Sep 6 2004, 03:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 07:53 PM |
