The two wheel lift ..., Anything i can do about that? |
SirAndy |
May 4 2015, 11:09 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Going through some of my pictures, i started to wonder if there is something i can do about this?
(IMG:style_emoticons/default/idea.gif) |
McMark |
May 5 2015, 12:05 AM
Some thoughts I pulled out of my hair:
Lower CG- either by moving weight down, or moving the whole car down. Stiffer suspension- you obviously have a nice F/R balance, make everything harder to keep the weight from shifting towards the outside. Apparently it only does it when you're turning right. (IMG:style_emoticons/default/poke.gif) |
SirAndy |
May 5 2015, 10:45 AM
Apparently it only does it when you're turning right. (IMG:style_emoticons/default/poke.gif) Doh! Then all i need is a 220lbs passenger and i should be fine ... (IMG:style_emoticons/default/biggrin.gif) |
Randal |
May 5 2015, 11:55 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Apparently it only does it when you're turning right. (IMG:style_emoticons/default/poke.gif) Doh! Then all i need is a 220lbs passenger and i should be fine ... (IMG:style_emoticons/default/biggrin.gif) Questions: What springs are you running? Are you running a limit slip differential? |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:31 AM |
