The two wheel lift ..., Anything i can do about that? |
SirAndy |
May 4 2015, 11:09 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Going through some of my pictures, i started to wonder if there is something i can do about this?
(IMG:style_emoticons/default/idea.gif) |
ThePaintedMan |
May 6 2015, 06:29 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Those runs are on slicks right?
Also, the rear swaybar has an impact, probably fairly significantly with slicks. It's probably the biggest reason why the rear is off the ground. With slicks and without bigger torsion bars, I bet that the front is probably always going to lift. |
SirAndy |
May 6 2015, 10:34 AM
Those runs are on slicks right? Also, the rear swaybar has an impact, probably fairly significantly with slicks. It's probably the biggest reason why the rear is off the ground. With slicks and without bigger torsion bars, I bet that the front is probably always going to lift. GoodYear R250 slicks. The chassis doesn't twist much with the cage and all so usually the whole side of the car just comes up. It happens quite often at AX and can be somewhat scary. I'm just afraid i'm gonna flip it over one of these days. (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 09:08 AM |
