Need Raby 9590 cam info |
Frank S |
May 6 2015, 04:53 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Hi there,
I'm about to order parts for my engine rebuild. The plan is to upgrade a 2.0 GA D-Jet engine as following: 2056cc Stroke 71mm (stock) CR 9:1 Raby 9590 cam SSI Heatexchangers Original Muffler The only thing stoping me right now is that I need verify CO2 emissions every 2 years here in Germany. My questions are now: 1. Does this set up idle well and stable at 900-950RPM 2. Does it reach the 3% CO2 spec. in idle I know that a none stock cam should not idle so low, this will be just for the time of the measurement. Without reaching this spec values I not able to register the car here in Germany :-( Thanks and best Regards, Frank |
Bleyseng |
May 8 2015, 07:28 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Happier with a stock cam, no. A stock cam engine get max 95-100hp on a great day most don't even come close to that on a dyne.
The Raby cam wakes up the engine to 115-120hp and runs cooler. Yes, it takes time to tune the MPS and get the timing right but big deal. Oh and it idles at 1000rpms and sounds great. (IMG:style_emoticons/default/beerchug.gif) |
Frank S |
May 8 2015, 08:40 AM
Happier with a stock cam, no. A stock cam engine get max 95-100hp on a great day most don't even come close to that on a dyne. The Raby cam wakes up the engine to 115-120hp and runs cooler. Yes, it takes time to tune the MPS and get the timing right but big deal. Oh and it idles at 1000rpms and sounds great. (IMG:style_emoticons/default/beerchug.gif) Hi Geoff, it looks like I'll oder a cam kit from TypeIVStore and use just the upper part of it with a stock cam in first place. If the car is once registered I can upgrade with the 9590 and the lower valve train plus springs... Much easier to dial everything in if I can drive the car. Are you running the original distributor with a limitation on centrifugal? Best Regards, Frank |
Lo-Fi Version | Time is now: 8th June 2024 - 05:13 PM |
