> Brake Pedal Adjust?
richardL
post Sep 4 2004, 01:23 PM
I was trying to fit the new pedal board I have and it won't fit as it keeps binding on the brake pedal. When I played with the pedal I can move it off of the rest towards the master cylinder about 3/4" using one finger. I believe the free play should be closer to 1mm?
Anyhow it seems to me that I should be adjusting the rubber stop forwards to reduce the play - and this would move the rest position of the pedal forwards and reduce the free play and hence also the pedal board to fit in. Is that correct? or am I missing something?
OK...
How do I do that adjustment? I can't see any way of moving the rubber stop towards the front of the car as it is attached to the bearing tube. Essentially I am trying to stop the spring pushing the pedal up too far, but I can't see how to make that adjustment. I think I have read that the pedal height is adjustable?
Hope this is clear,
Thanks,
Richard
richardL
post Sep 7 2004, 12:51 PM
I don't think the crossbar is a strong as the firewall. I bashed at it for several hours and was able to flatten it a bit more but not enough to get the new pedal board on - it still overlaps by maybe a 1/4 inch.
I needed to get things back together so I could work on the carbs, so I reassembled it all for now and got the car running last night.
I still have a dubious temp guage, it reads around 120 but doesn't go any higher and I can't believe that, so I will fix that and then try to play at carb balancing.
Thanks for the help,
Richard
richardL   Brake Pedal Adjust?   Sep 4 2004, 01:23 PM
davep   Normally the brake pedal adjustment is done with t...   Sep 4 2004, 01:49 PM
richardL   The brakes worked very well when I last drove it. ...   Sep 4 2004, 01:58 PM
Brad Roberts   The brake pedal is not adjustable (just the free p...   Sep 4 2004, 02:05 PM
richardL   Well that simplifies things. So according to the ...   Sep 4 2004, 02:12 PM
davep   Yes, the finger test is good. Once you start to fe...   Sep 4 2004, 02:25 PM
richardL   I can get the board on, and I can just screw down ...   Sep 4 2004, 02:40 PM
Engman   The pedal boards can be a little tough to get into...   Sep 4 2004, 03:30 PM
Brad Roberts   yeah.. show us a pic.. I know you have a camera......   Sep 4 2004, 03:31 PM
richardL   OK, try these. The board is on and I attach the r...   Sep 4 2004, 03:57 PM
richardL   Now try the other way - attach the left hand mount...   Sep 4 2004, 03:59 PM
richardL   The clutch pedal fits fine, but notice that the bo...   Sep 4 2004, 04:01 PM
Engman   How far off is the other mount hole? M   Sep 4 2004, 04:34 PM
richardL   Whichever side I attach, the board on the other si...   Sep 4 2004, 04:38 PM
Engman   Remove the screw and mount on the lh side. Board l...   Sep 4 2004, 04:54 PM
richardL   Mark, If you look at the first picture I had only...   Sep 4 2004, 05:16 PM
richardL   A few minutes with the saw and I removed that lowe...   Sep 4 2004, 05:38 PM
Jeroen   Richard, It's a little hard to tell by your p...   Sep 4 2004, 06:12 PM
Jeroen   maybe the bolt for the brake stop is missing or br...   Sep 4 2004, 06:13 PM
richardL   The nut is in place and the geometry looks like yo...   Sep 4 2004, 06:24 PM
Jeroen   Weird... Loosen the nuts on the MC and see if you ...   Sep 4 2004, 06:37 PM
Brad Roberts   That is F'd up. :agree: I wonder how the MC c...   Sep 4 2004, 07:07 PM
richardL   All looks OK...   Sep 4 2004, 07:19 PM
richardL   Sorry about the focus...   Sep 4 2004, 07:21 PM
redshift   The rod is properly seated? What is up with that....   Sep 5 2004, 01:20 AM
davep   I don't like the looks of the master, it seems...   Sep 5 2004, 12:04 PM
richardL   So the cluster should be flush with the floor from...   Sep 5 2004, 12:21 PM
Engman   Pull the cluster. lets see what is in there. Shoot...   Sep 5 2004, 01:13 PM
richardL   your wish is my command.... I pulled the cluster ...   Sep 5 2004, 02:45 PM
richardL   and the reason I think is because of two things. 1...   Sep 5 2004, 02:46 PM
richardL   and (2) it looks like the firewall at this point i...   Sep 5 2004, 02:48 PM
richardL   ...inside view....   Sep 5 2004, 02:49 PM
seanery   looks pushed in 1/4 to 1/2" huh?   Sep 5 2004, 02:49 PM
richardL   So... Considering that aesthetics are not importa...   Sep 5 2004, 02:52 PM
richardL     Sep 5 2004, 02:53 PM
sgomes   My 2cents is always the same 2cents: Fix it right...   Sep 5 2004, 02:56 PM
seanery   Shannon, your avatar looks like a clown that was i...   Sep 5 2004, 02:57 PM
sgomes   :chairfall: No, it's really me! It was f...   Sep 5 2004, 03:03 PM
richardL     Sep 5 2004, 03:19 PM
Engman   Yep - its pushed in.... time for :smash: . I am ...   Sep 5 2004, 04:10 PM
richardL   I was able to regain about 1/4" or so (as measured...   Sep 5 2004, 04:29 PM
davep   Well, that about settles what the problem is. Now ...   Sep 5 2004, 05:58 PM
richardL   I had thought of a jack but I need to brace it aga...   Sep 6 2004, 10:05 AM
davep   I would use the crossbar (front seat support) but ...   Sep 7 2004, 11:10 AM
richardL   I don't think the crossbar is a strong as the ...   Sep 7 2004, 12:51 PM
- Lo-Fi Version Time is now: 11th July 2025 - 05:01 PM
