| Luke M |
Jun 21 2013, 05:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,608 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
I figured why not start this thread. The car is a 74 914 2.0 that's been sitting since the early 90's. It was parked outside/in the woods up until my brother purchased it last fall. It didn't look too bad from 20 feet away but when you look closer it gets pretty bad. So, here's the plan... strip the car, fix the rust problems, paint it, add a 5 lug suspension, and convert it to a 3.0 6. Stay tuned for pics of the progress..
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) |
| peteyd |
May 15 2015, 02:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 744 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Looks great Luke! How did the cross member fit in? Its good to see the new parts installed. I rarely get much feedback about the new parts Im making.
I will eventually make the other bits that attach to the outer firewall also. |
| Luke M |
May 15 2015, 03:09 PM
Looks great Luke! How did the cross member fit in? Its good to see the new parts installed. I rarely get much feedback about the new parts Im making. I will eventually make the other bits that attach to the outer firewall also. Hi Pete, Other then the small problem we talked about on the phone it went in fairly easy. We got all of the replacement metal from RD and so far what we've installed fits well. Most panels needed some minor fitting adjustments other then that the fit was great. Keep up the great work on making us these and more replacement panels. Thanks again for some great products. |
| 3d914 |
May 15 2015, 05:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Looks great Luke! How did the cross member fit in? Its good to see the new parts installed. I rarely get much feedback about the new parts Im making. I will eventually make the other bits that attach to the outer firewall also. Hi Pete, Other then the small problem we talked about on the phone it went in fairly easy. We got all of the replacement metal from RD and so far what we've installed fits well. Most panels needed some minor fitting adjustments other then that the fit was great. Keep up the great work on making us these and more replacement panels. Thanks again for some great products. While Pete's watching - do you make a weldin piece for the master cylinder at the pedal cluster? Luke, didn't you repair this area also? My whole front floor is great except for that portion behind the pedal cluster. |
| Luke M |
May 15 2015, 06:59 PM
Looks great Luke! How did the cross member fit in? Its good to see the new parts installed. I rarely get much feedback about the new parts Im making. I will eventually make the other bits that attach to the outer firewall also. Hi Pete, Other then the small problem we talked about on the phone it went in fairly easy. We got all of the replacement metal from RD and so far what we've installed fits well. Most panels needed some minor fitting adjustments other then that the fit was great. Keep up the great work on making us these and more replacement panels. Thanks again for some great products. While Pete's watching - do you make a weldin piece for the master cylinder at the pedal cluster? Luke, didn't you repair this area also? My whole front floor is great except for that portion behind the pedal cluster. Yes, I had to fix the pedal area. I got a piece from a parts car that Bruce was cutting up. |
Luke M Progress thread 74 2.0 to 3.0 6 Jun 21 2013, 05:56 AM
Cupomeat Looking forward to it!
:headbanger: Jun 21 2013, 06:55 AM
PanelBilly Hey, that's my plan! Jun 21 2013, 08:11 AM
Dasnowman
I figured why not start this thread. The car is a... Jun 21 2013, 04:28 PM
Luke M
I figured why not start this thread. The car is ... Jun 21 2013, 07:41 PM
[quote name='Dasnowman' post='1883388' date='Jun ... Sep 13 2021, 05:50 PM
Luke M
[quote name='Dasnowman' post='1883388' date='Jun... Sep 13 2021, 06:41 PM
Luke M Here's a few pics of the car when it was purch... Jun 22 2013, 11:44 AM
Luke M Rust repair in the works.. :sawzall: :smash:
:w... Jun 22 2013, 12:26 PM
Spoke Good luck and happy welding.
Looks like a typical... Jun 22 2013, 05:40 PM
Luke M
Looks like a typica... Jun 22 2013, 06:57 PM
Luke M Replacing the r/r inner control arm mount was a re... Jun 24 2013, 07:08 AM
Luke M Some of the parts that will be used :
Original 91... Jun 25 2013, 07:48 AM
rick 918-S Nice start! :smash: :sawzall: :welder: Jun 25 2013, 08:06 AM
Luke M I'm back to it here. Finally had some time to ... Sep 21 2013, 08:58 AM
Jamesmichael73 Thats some nice work. I will be following this bui... Sep 21 2013, 09:32 AM
r_towle Parked outside in Rochester Ny, the northeast capi... Sep 21 2013, 10:17 AM
Luke M Finally got some sheet metal in from a CA parts ca... Sep 30 2013, 06:36 PM
914forme Thats some nice work your doing. And don't fe... Sep 30 2013, 06:48 PM
Luke M My brother and I finally got a few things done on ... Nov 24 2013, 08:20 AM
trojanhorsepower Man that looks familiar. Looks like it is going we... Nov 24 2013, 09:16 AM
jimkelly that's a pretty big - and nicely done - repair... Nov 24 2013, 09:40 AM
Luke M The door gaps should be ok as I placed the cross b... Nov 24 2013, 10:04 AM
trojanhorsepower Luke M,
Are you using a stone head or wire or pad... Nov 24 2013, 10:32 AM
Luke M [quote name='trojanhorsepower' date='N... Nov 27 2013, 10:56 AM
maddog Nice work Luke, I am enjoying the pics and watchin... Nov 27 2013, 11:20 AM
wndsnd Well I know what you are dealing with. You are lu... Nov 27 2013, 11:32 AM
Luke M The work continues. The right long is done and sta... Mar 2 2014, 07:49 PM
Luke M It's been a while since I updated this so here... Aug 18 2014, 07:31 AM
Luke M Well now that the cold weather has kinda gone away... Apr 6 2015, 11:31 AM
nathansnathan
Well now that the cold weather has kinda gone awa... Apr 6 2015, 12:26 PM
Luke M
Well now that the cold weather has kinda gone aw... Apr 6 2015, 02:58 PM
Cairo94507 Wow- Nice work. Doing it right is the only way to... Apr 6 2015, 12:24 PM
Luke M
Wow- Nice work. Doing it right is the only way t... Apr 6 2015, 03:19 PM
Luke M It's been a busy weekend. We got the lower out... Apr 13 2015, 11:10 AM
nathansnathan That looks awesome. :first:
Don't forget the... Apr 13 2015, 03:35 PM
Luke M
Don't forget th... Apr 13 2015, 06:39 PM
trojanhorsepower Lookin good! Apr 13 2015, 06:42 PM
914Sixer Top Notch job !!! Apr 13 2015, 07:18 PM
Luke M We got the floor pan/seat mount reinforcement all ... Apr 19 2015, 08:09 PM
914350 Looking great!!! Apr 19 2015, 11:40 PM
Luke M Back to it here.. :smash: :welder:
We got the ... Jun 4 2015, 09:28 AM
Luke M My brother and I got a few more things done on his... Jun 10 2015, 08:49 AM
Luke M We got the drivers side chassis stiffener, door si... Jul 1 2015, 07:09 AM
Luke M Wrapped up the drivers side and moved on to the pa... Jul 2 2015, 08:12 PM
Luke M Moving forward on the pass side. Cut out and repla... Jul 12 2015, 08:26 PM
Luke M It's been way too hot and muggy here to do any... Aug 6 2015, 09:04 AM
Luke M The case and a few other parts came back from the ... Aug 25 2015, 05:54 AM
Luke M It's too darn hot 90+ in the garage to do any ... Sep 5 2015, 06:41 AM
Phoenix914 :popcorn:
Looks like you're making good prog... Sep 5 2015, 07:06 AM
Luke M I got the head studs installed and set to 135 mm .... Sep 5 2015, 06:51 PM
Luke M Got the right rear GT kit installed. Started on th... Oct 5 2015, 08:50 AM
Luke M Started building the chassis jig and the brackets ... Oct 10 2015, 08:42 AM
jmitro fantastic work; very thorough.
Just curious why y... Oct 10 2015, 09:10 AM
Luke M
Just curious why ... Oct 10 2015, 09:30 AM
trojanhorsepower Great work guys! Oct 10 2015, 11:01 AM
Luke M Slow winter here but we got two transmissions rebu... Mar 15 2016, 11:26 AM
Luke M 3.0 is almost done. Waiting on cams, rockers then ... May 19 2018, 10:25 AM
Lucky9146 Man that is a labor of love. You are doing it rig... May 19 2018, 11:35 AM
mepstein What kind of induction on the 3.0 May 19 2018, 02:17 PM
Luke M
Weber 40 IDA... May 19 2018, 05:20 PM
Justinp71
Weber 40 ID... Apr 29 2021, 02:53 PM
Luke M
[quote name='Luke M' post='2610914' date='May 19 ... Apr 30 2021, 06:40 AM
Luke M We've been working away slowly on my brothers ... Jun 25 2019, 06:31 AM
Jamie
We've been working away slowly on my brothers... Jun 25 2019, 09:27 AM
Luke M Got a few more things knocked off my brothers 914 ... May 19 2020, 01:58 PM
Luke M Worked on the rear trunk pan today. The spot welde... Mar 13 2021, 05:45 PM
Root_Werks I really like the spot welder you are using. Yes,... Mar 16 2021, 05:13 PM
Luke M
I really like the spot welder you are using. Yes... Mar 16 2021, 06:18 PM
Luke M My brothers car has reached a huge milestone on We... Apr 29 2021, 07:33 AM
Shivers Nice work Apr 29 2021, 03:16 PM
rgalla9146 Luke.....you are a friggin' glutton.
A ve... Apr 29 2021, 07:24 PM
Luke M [quote name='rgalla9146' date='Apr 29 ... Apr 30 2021, 06:31 AM
Luke M Oh what a PIA it has been getting all of this sand... May 5 2021, 08:36 AM
Luke M Well after weeks of cleaning and prepping we final... Aug 19 2021, 01:53 PM
Cairo94507 Great progress and it is a roller again. :beer2: Aug 19 2021, 03:01 PM
rgalla9146 Luke your brothers car looks great !
When... Aug 19 2021, 03:06 PM
Luke M
Whe... Aug 19 2021, 07:27 PM
Luke M We've been working away here.. Got the brakes ... Sep 11 2021, 06:30 PM
Root_Werks That's some fast progress! Looking good... Sep 13 2021, 05:02 PM
Justinp71 Looking good :trophy: Sep 13 2021, 05:53 PM
Luke M We've been chipping away at the list here. Got... Oct 2 2021, 06:46 PM
Luke M We got the 3.0 on the test stand today. I'm go... Oct 10 2021, 05:44 PM
Luke M Fired up the 3.0 tonight... She's a runner and... Oct 14 2021, 07:29 PM
Krieger Congratulations! Great feeling isn't it Oct 14 2021, 10:52 PM
rgalla9146 Go Go Go Luke !
Engine start up before i... Oct 15 2021, 06:26 AM
Luke M
Go Go Go Luke !
Engine start up before ... Oct 15 2021, 11:02 AM
Root_Werks Holy running engines Batman! I applaud your a... Oct 15 2021, 08:57 AM
Dion Nice work going on there. Congrats on the engine s... Oct 15 2021, 11:23 AM
Luke M Lets see if the video works..
https://youtu.be/Y8... Oct 16 2021, 09:53 AM
lesorubcheek
https://youtu.be/Y... Oct 16 2021, 02:00 PM
Luke M We had a busy weekend here. Got the wire harness a... Oct 24 2021, 07:37 PM
Luke M So I'm stuck with the harness install in the e... Oct 25 2021, 07:02 PM
rgalla9146 Luke how about this ?
Work up the dimension... Oct 25 2021, 08:10 PM
Mikey914 The fix had been to use a small section of sheet m... Oct 26 2021, 02:19 AM
Justinp71 Nice build! That will be a blast to drive. Oct 26 2021, 12:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th October 2026 - 06:23 PM |
