| 914itis |
May 16 2015, 09:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I installed the heat exchangers on the six , all flappers and hoses installed with the exception of the blower tube. The output for the blower is capped.
I started he car and let it idle for 25 minutes and no heat . Do I need the blower on the six exchangers ? Where can I get these j tubes? |
| screenguy914 |
May 16 2015, 10:53 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Can you post a photo of your engine compartment and under-engine cabin air components? There's something askew with your hot air path/passages.
If you equipped and plumbed your system like an early 911s, you don't need the engine-mounted blower motor, although it does provide more air volume through the system, especially at idle and low speed. Sherwood |
914itis No heat ? May 16 2015, 09:22 PM
Cairo94507 I agree 100%- a stock Six heat exchanger system wi... May 16 2015, 11:04 PM
mepstein the heat should pour out when you step on the gas.... May 17 2015, 04:59 AM
Spoke
the heat should pour out when you step on the gas... May 17 2015, 06:54 AM
GeorgeRud If you're using a later large displacement eng... May 17 2015, 08:36 AM
914itis I will take a picture later . I will also go for a... May 17 2015, 08:45 AM
914itis I drove the car for an hr and no luck .
I unhook... May 17 2015, 08:56 PM
mepstein Top of the engine pics? May 17 2015, 09:22 PM
914itis Ill get you one in tomorrow, but nothing is plumbe... May 17 2015, 09:32 PM
Ill get you one in tomorrow, but nothing is plumb... May 17 2015, 11:05 PM
914itis
Ill get you one in tomorrow, but nothing is plum... May 18 2015, 08:32 AM
[quote name='mepstein' post='2188077' date='May 1... May 18 2015, 08:58 AM
914itis
[quote name='mepstein' post='2188077' date='May ... May 18 2015, 09:00 AM
[quote name='mepstein' post='2188165' date='May 1... May 18 2015, 09:28 AM
914itis No , that a why I mentioned that the blower fan is... May 18 2015, 03:46 AM
No , that a why I mentioned that the blower fan i... May 18 2015, 04:37 AM
914itis
No , that a why I mentioned that the blower fan ... May 18 2015, 06:54 AM
[quote name='mepstein' post='2188102' date='May 1... May 18 2015, 08:21 AM
914itis No , that a why I mentioned that the blower fan is... May 18 2015, 03:47 AM
GeorgeRud The engine fan is absolutely necessary to push air... May 18 2015, 07:18 AM
914itis
The engine fan is absolutely necessary to push ai... May 18 2015, 07:32 AM
914itis Thanks . May 18 2015, 09:38 AM
rgalla9146 Paul
No need for J pipes on a 6
Engine cooli... May 18 2015, 09:52 AM
mepstein I'm pretty sure you want the heat hooked up fo... May 18 2015, 09:59 AM
euro911 So Paul, do you already have a set of fan duct noz... May 18 2015, 10:36 AM
914itis Yes I do. They are currently capped. May 18 2015, 10:58 AM
Great. Your... May 18 2015, 12:42 PM
Steve I just bought a set of these from Sierra Madre. N... May 18 2015, 10:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:55 PM |
