| jack20 |
May 16 2015, 11:44 PM
Member ![]() ![]() Group: Members Posts: 422 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California
Hello,
My car is a 74, has had no body damage and appears very straight. The only problem is uneven gaps in the headlight area. Has anyone come up with a logical sequence of alignment of the three components mentioned in the thread title? I have gone at this three times now and always end up with unsatisfactory results. Thanks, Jack |
| 76-914 |
May 17 2015, 08:03 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I set the hood first and lights last. Have you tried to loosen the brackets that hold the eyebrow. Are the conical rubber tit's worn? Is your hood seal new?
| jack20 |
May 17 2015, 08:32 AM
I set the hood first and lights last. Have you tried to loosen the brackets that hold the eyebrow. Are the conical rubber tit's worn? Is your hood seal new? I didn't know that the eyebrows had moveable brackets. The rubber grommets are either new or in great condition. Hood seal is also in great condition. I'll start with the hood...again. This is my third try at this. The hood seems to want to return to its previous position. I've loosened the bracket on both sides of the headlight assembly. Where are theyebrow brackets? Thanks for the response. Jack |
jack20 Alignment of Hood, Headlight and Eyebrows May 16 2015, 11:44 PM
r_towle
I set the hood first and lights last. Have you tr... May 17 2015, 08:18 PM
toolguy There are no 'eyebrow' brackets, only the ... May 17 2015, 09:23 AM
Johny Blackstain
There are no 'eyebrow' brackets, only the... May 17 2015, 09:32 AM
r_towle Hood first, check gaps at fender and cowl...get th... May 17 2015, 09:36 AM
altitude411 :agree: You see so many w/ hoods that aren't... May 17 2015, 10:51 AM
:agree: You see so many w/ hoods that aren... May 17 2015, 01:02 PM
Kansas 914
It's up to you but the rubber grommets are t... May 17 2015, 01:44 PM
pilothyer An article here on The World by Sir Andy may help ... May 17 2015, 11:38 AM
altitude411 Are your kidding me? :idea: ... maybe I should rem... May 17 2015, 02:17 PM
RARE 6 Just about to wrap up reassembly of my -6 after a ... May 17 2015, 10:08 PM
altitude411 http://shop.914rubber.com/914-Eyebrow-grom...of-6-... May 17 2015, 10:13 PM
RARE 6
http://shop.914rubber.com/914-Eyebrow-grom...of-6... May 17 2015, 11:33 PM
PanelBilly Keep in mind that you can alter the arch of the ho... May 17 2015, 10:22 PM
mbseto
Are your kidding me? :idea: ... maybe I should re... May 18 2015, 06:58 AM
altitude411 :unsure: Hey guy's I appreciate the concern... May 18 2015, 07:11 AM
Kansas 914
:unsure: Hey guy's I appreciate the concer... May 18 2015, 07:57 AM
altitude411 :headbang: :screwy: Ok, enough. Please, I'v... May 18 2015, 08:08 AM
Kansas 914
:headbang: :screwy: Ok, enough. Please, I... May 18 2015, 12:39 PM
RobW The head lights adjust more than you think. Like o... May 18 2015, 08:29 AM
jack20 As always, you have provided great information...a... May 18 2015, 10:56 AM
ctc911ctc I am working this problem right now - I have EVERY... Jan 30 2020, 09:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:44 AM |
