> 74 2.0 F.I. NO spark, Ran before new battery
Nemisus
post May 17 2015, 02:14 PM
So I am stumped. When I took delivery of my newly acquired 74 914 the car would start up just fine with a jump box.
I went out and bought a new battery and now I have no spark... at lest from I can tell doing the simple spark tests I have done.
I just did an Ohms test on my Ignition coil and here is what I got
Primary: 1.4
Secondary: 10.41
Per the Pelican Technical Article I should see readings like this:
primary coil winding's should give a reading of 0.3-0.6 ohms. Secondary coils should be near 600 ohms.
If I understand my results I am significantly higher than where I should be? But does that mean my coil is is the cause of no spark.
The only thing I changed was a busted fuel line and put in a new battery... Now the car will not start.
Any ideas on where else to look?
Thanks in advance
Cheers
Nem
Nemisus
post May 17 2015, 09:26 PM
QUOTE(Dave_Darling @ May 17 2015, 07:55 PM) *
The 914 does not have a CD ignition which would whine when the power was on. Most 911s do, and the 914-6, but not the four-cylinder cars.
The hot coil is likely because your points were closed, running current through the coil while the key was on.
Here's a test: Unplug the (-) wires from the coil. Hook a spark plug wire with a plug attached to the coil center terminal. Tape the plug so the outer electrodes or the threaded part is grounded. Now hook a wire to ground, touch the wire to the coil (-) terminal, then pull it away. You should get a spark from the plug. If you do, the coil is working the way it should.
--DD
Thanks Dave,
I have been reading so much Porsche literature in the past few days it is possible I was reading about the 914-6.
I am betting my coil is working fine... it would be too coincidental for 2 coils to be non functional.
I will try the test tomorrow if I have daylight enough. I may not have time to even look at the 914 until next weekend due to full time work and school.
One test I have done is pull a plug, attach it to its plug wire and have my wife turn over the key while I ground the plug... NO spark that way.
Only thing left to go through is the cap, rotor and wires and possibly the distributor.
I'll be ordering a tune up kit tonight... it wont hurt at this point.
Any suggestions on where to buy? Would like to stay Bosch.
Nemisus   74 2.0 F.I. NO spark   May 17 2015, 02:14 PM
Dave_Darling   Look for anything you might have bumped when chang...   May 17 2015, 03:37 PM
Nemisus   Look for anything you might have bumped when chan...   May 17 2015, 04:34 PM
Nemisus   So I decided to eliminate the possibility that the...   May 17 2015, 06:49 PM
flash914   Coil wire Check the resistance.   May 17 2015, 06:52 PM
StarBear   Just wondering as I think I have the same/similar ...   Nov 11 2018, 09:01 AM
Nemisus   Which wire flash? The black wire providing power?...   May 17 2015, 08:44 PM
Dave_Darling   The 914 does not have a CD ignition which would wh...   May 17 2015, 08:55 PM
Nemisus   The 914 does not have a CD ignition which would w...   May 17 2015, 09:26 PM
Nemisus   Found a complete Bosch Tune up package for a decen...   May 18 2015, 10:19 AM
Nemisus   After changing the cap, rotor, wires, points, cond...   May 23 2015, 06:21 PM
Dave_Darling   NO 1st gear at all. Goes into 1st well enough, b...   May 23 2015, 08:55 PM
Jeff Bowlsby   Are you anywhere near Sonoma? If so, maybe take t...   May 23 2015, 08:34 PM
Nemisus   Are you anywhere near Sonoma? If so, maybe take ...   May 23 2015, 09:57 PM
Dave_Darling   QC on the Bosch Platinum plugs is... not great. ...   May 23 2015, 11:22 PM
Nemisus   Dave, That is disappointing news as these plugs c...   May 24 2015, 10:39 AM
Spoke   I want to refresh the ignition system and fuel sy...   May 24 2015, 12:45 PM
stugray   Notes from my plugs research: NGK BP6ES voted bes...   May 24 2015, 11:44 AM
Dave_Darling   BOSCH W7CC for carbs (then adjust heat range base...   May 24 2015, 04:44 PM
Nemisus   Notes from my plugs research: NGK BP6ES voted be...   May 24 2015, 01:32 PM
The Cabinetmaker   The cap'n will also tell you (and I agree), if...   May 24 2015, 02:19 PM
RenoRoger   The cap'n will also tell you (and I agree), i...   May 24 2015, 02:42 PM
Nemisus   Ive been reading a bit about this. Seems some hav...   May 24 2015, 03:41 PM
Nemisus   FYI, The plugs that that came with the tune up ki...   May 24 2015, 08:36 PM
- Lo-Fi Version Time is now: 16th June 2024 - 07:26 PM
