> No heat ?
914itis
post May 16 2015, 09:22 PM
I installed the heat exchangers on the six , all flappers and hoses installed with the exception of the blower tube. The output for the blower is capped.
I started he car and let it idle for 25 minutes and no heat .
Do I need the blower on the six exchangers ?
Where can I get these j tubes?
914itis
post May 17 2015, 09:32 PM
Ill get you one in tomorrow, but nothing is plumbed rom the top to the HE's
post May 17 2015, 11:05 PM
914-6 GT in waiting
QUOTE(914itis @ May 17 2015, 11:32 PM) *
Do you have the hoses from the side of the alternator fan to the HE's?
914itis
post May 18 2015, 08:32 AM
QUOTE(mepstein @ May 18 2015, 01:05 AM) *
Mark,
Looking at this picture , does the flex pipe shown attaches to a j pipe as in the T4's or does it go all the way down to the exchangers?.
Thanks
post May 18 2015, 08:58 AM
914-6 GT in waiting
QUOTE(914itis @ May 18 2015, 10:32 AM) *
Mark,
Thanks
Goes through a hole on the engine tin down to the he's. All one length on each side. I have some factory tin if you need pictures and size for the hole in the tin.
914itis   No heat ?   May 16 2015, 09:22 PM
screenguy914   Can you post a photo of your engine compartment an...   May 16 2015, 10:53 PM
Cairo94507   I agree 100%- a stock Six heat exchanger system wi...   May 16 2015, 11:04 PM
mepstein   the heat should pour out when you step on the gas....   May 17 2015, 04:59 AM
Spoke   the heat should pour out when you step on the gas...   May 17 2015, 06:54 AM
GeorgeRud   If you're using a later large displacement eng...   May 17 2015, 08:36 AM
914itis   I will take a picture later . I will also go for a...   May 17 2015, 08:45 AM
914itis   I drove the car for an hr and no luck . I unhook...   May 17 2015, 08:56 PM
mepstein   Top of the engine pics?   May 17 2015, 09:22 PM
914itis   Ill get you one in tomorrow, but nothing is plumbe...   May 17 2015, 09:32 PM
mepstein   Ill get you one in tomorrow, but nothing is plumb...   May 17 2015, 11:05 PM
914itis   Ill get you one in tomorrow, but nothing is plum...   May 18 2015, 08:32 AM
mepstein   [quote name='mepstein' post='2188077' date='May 1...   May 18 2015, 08:58 AM
914itis   [quote name='mepstein' post='2188077' date='May ...   May 18 2015, 09:00 AM
mepstein   [quote name='mepstein' post='2188165' date='May 1...   May 18 2015, 09:28 AM
914itis   No , that a why I mentioned that the blower fan is...   May 18 2015, 03:46 AM
mepstein   No , that a why I mentioned that the blower fan i...   May 18 2015, 04:37 AM
914itis   No , that a why I mentioned that the blower fan ...   May 18 2015, 06:54 AM
mepstein   [quote name='mepstein' post='2188102' date='May 1...   May 18 2015, 08:21 AM
914itis   No , that a why I mentioned that the blower fan is...   May 18 2015, 03:47 AM
GeorgeRud   The engine fan is absolutely necessary to push air...   May 18 2015, 07:18 AM
914itis   The engine fan is absolutely necessary to push ai...   May 18 2015, 07:32 AM
914itis   Thanks .   May 18 2015, 09:38 AM
rgalla9146   Paul No need for J pipes on a 6 Engine cooli...   May 18 2015, 09:52 AM
mepstein   I'm pretty sure you want the heat hooked up fo...   May 18 2015, 09:59 AM
euro911   So Paul, do you already have a set of fan duct noz...   May 18 2015, 10:36 AM
914itis   Yes I do. They are currently capped.   May 18 2015, 10:58 AM
mepstein   Yes I do. They are currently capped. Great. Your...   May 18 2015, 12:42 PM
Steve   I just bought a set of these from Sierra Madre. N...   May 18 2015, 10:31 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:29 PM
