| 914itis |
May 16 2015, 09:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I installed the heat exchangers on the six , all flappers and hoses installed with the exception of the blower tube. The output for the blower is capped.
I started he car and let it idle for 25 minutes and no heat . Do I need the blower on the six exchangers ? Where can I get these j tubes? |
| 914itis |
May 17 2015, 09:32 PM
Ill get you one in tomorrow, but nothing is plumbed rom the top to the HE's
| mepstein |
May 17 2015, 11:05 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Ill get you one in tomorrow, but nothing is plumbed rom the top to the HE's Do you have the hoses from the side of the alternator fan to the HE's? Attached image(s)
| 914itis |
May 18 2015, 08:32 AM
Ill get you one in tomorrow, but nothing is plumbed rom the top to the HE's Do you have the hoses from the side of the alternator fan to the HE's? Mark, Looking at this picture , does the flex pipe shown attaches to a j pipe as in the T4's or does it go all the way down to the exchangers?. Thanks |
| mepstein |
May 18 2015, 08:58 AM
Ill get you one in tomorrow, but nothing is plumbed rom the top to the HE's Do you have the hoses from the side of the alternator fan to the HE's? Mark, Looking at this picture , does the flex pipe shown attaches to a j pipe as in the T4's or does it go all the way down to the exchangers?. Thanks Goes through a hole on the engine tin down to the he's. All one length on each side. I have some factory tin if you need pictures and size for the hole in the tin. |
| 914itis |
May 18 2015, 09:00 AM
Ill get you one in tomorrow, but nothing is plumbed rom the top to the HE's Do you have the hoses from the side of the alternator fan to the HE's? Mark, Looking at this picture , does the flex pipe shown attaches to a j pipe as in the T4's or does it go all the way down to the exchangers?. Thanks Goes through a hole on the engine tin down to the he's. All one length on each side. I have some factory tin if you need pictures and size for the hole in the tin. Yes please with the size of the holes and the lenght of the hose if possible . |
| mepstein |
May 18 2015, 09:28 AM
Ill get you one in tomorrow, but nothing is plumbed rom the top to the HE's Do you have the hoses from the side of the alternator fan to the HE's? Mark, Looking at this picture , does the flex pipe shown attaches to a j pipe as in the T4's or does it go all the way down to the exchangers?. Thanks Goes through a hole on the engine tin down to the he's. All one length on each side. I have some factory tin if you need pictures and size for the hole in the tin. Yes please with the size of the holes and the lenght of the hose if possible . Holes are 65mm diameter. I don't know how long the hose is. I know people buy from aircraft spruce.com I'm guessing 2 feet on each side but it's just a guess. someone who has a 6 will probably know. Attached image(s)
914itis No heat ? May 16 2015, 09:22 PM
screenguy914 Can you post a photo of your engine compartment an... May 16 2015, 10:53 PM
Cairo94507 I agree 100%- a stock Six heat exchanger system wi... May 16 2015, 11:04 PM
mepstein the heat should pour out when you step on the gas.... May 17 2015, 04:59 AM
Spoke
the heat should pour out when you step on the gas... May 17 2015, 06:54 AM
GeorgeRud If you're using a later large displacement eng... May 17 2015, 08:36 AM
914itis I will take a picture later . I will also go for a... May 17 2015, 08:45 AM
914itis I drove the car for an hr and no luck .
I unhook... May 17 2015, 08:56 PM
mepstein Top of the engine pics? May 17 2015, 09:22 PM
914itis No , that a why I mentioned that the blower fan is... May 18 2015, 03:46 AM
No , that a why I mentioned that the blower fan i... May 18 2015, 04:37 AM
914itis
No , that a why I mentioned that the blower fan ... May 18 2015, 06:54 AM
[quote name='mepstein' post='2188102' date='May 1... May 18 2015, 08:21 AM
914itis No , that a why I mentioned that the blower fan is... May 18 2015, 03:47 AM
GeorgeRud The engine fan is absolutely necessary to push air... May 18 2015, 07:18 AM
914itis
The engine fan is absolutely necessary to push ai... May 18 2015, 07:32 AM
914itis Thanks . May 18 2015, 09:38 AM
rgalla9146 Paul
No need for J pipes on a 6
Engine cooli... May 18 2015, 09:52 AM
mepstein I'm pretty sure you want the heat hooked up fo... May 18 2015, 09:59 AM
euro911 So Paul, do you already have a set of fan duct noz... May 18 2015, 10:36 AM
914itis Yes I do. They are currently capped. May 18 2015, 10:58 AM
Great. Your... May 18 2015, 12:42 PM
Steve I just bought a set of these from Sierra Madre. N... May 18 2015, 10:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:35 PM |
