> planning my new 914 garage
siverson
post Mar 28 2015, 09:41 PM
We bought a new house many months ago, and the house needed a ton of work. The "house" part of our remodel is almost over, and now I'm making plans for the garage. I actually can't believe I haven't but more thought into this yet as one of the primary reasons we (or I (IMG:style_emoticons/default/smile.gif) ) liked the house is it has a big 2-car garage AND a big 3-car garage. And a big yard. Yay me.
Without benches or storage, I think 10 914s would actually fit in the 2 garages (tandem).
So... What do you think of my layout plan? Any other ideas below. The most space I've had to work with before this was a 22x20 2-car garage.
1. LIFT - We have to do some concrete work in the garage now anyways, so I think I may put some type of scissor lift in the floor. The ceiling is flat and only about 8.5' or 9.0'.
- Any lift recommendations?
- What needs to be plumbed into the lift? Just power or ? (I'm just starting my research now)
- Do you think the center position is the best for the lift?
2. BENCHES. What do you think? Benches as I drew along the top, or benches in the bottom stall? That closet has to stay there.
Any ideas or inspiration? Thanks!
-Steve
SixerJ
post May 19 2015, 05:25 PM
Region Association: England
After doing my garage I would consider the following
Lighting, loads of it / split on two switched ccts. One for popping in / picking stuff up and the second to beef up lighting levels for serious work
Ceiling mounted power sockets to avoid trailing power leads for things like trickle chargers / tripping over leads
Wall mounted surface trunking around the work bench, plus extra sockets around the place for general stuff
Really good insulated and draft excluded sectional garage door
Decent two pack epoxy floor paint / paint walls / ceiling before electrical 1st fix
Consider looking for ex office metal lateral filing units. I picked up some three draw units FOC and they work great for shallow / tall storage for things like paint, power tools, larger spare parts. Pull the drawer out and it's right there
Plumbed in air lines?
L6-20 or 30 socket for say a big welder? Not really sure if this is applicable or even allowable by the AHJ in a domestic environment
Couple of RJ45 sockets for a phone & Ethernet for computer / SONOS etc.....
My garage is a bit of an awkward shape but lighting wise I have 8x 5ft and 6x 6ft battens which are salt and peppered on the two switched ccts. No more scrabbling in the dark for a dropped nut
siverson   planning my new 914 garage   Mar 28 2015, 09:41 PM
stevegm   All flared cars? No narrow body 914s? :-) Looks li...   Mar 28 2015, 09:56 PM
KELTY360   Install a motion sensor light aimed at the entry w...   Mar 28 2015, 11:58 PM
mepstein   I love my snap on mid rise lift Bought it used for...   Mar 29 2015, 01:05 AM
Big Len   Just a thought, but the lift might be better serve...   Mar 29 2015, 03:54 AM
somd914   Looking great. Our garage is 24' x 36' w...   Mar 29 2015, 07:28 AM
thieuster   Do not put the lift in the middle. At one point, y...   Mar 29 2015, 08:49 AM
KELTY360   Install a motion sensor light aimed at the entry ...   Mar 29 2015, 08:54 AM
Camaro Mike   The best place I know for garage inspiration is st...   Mar 29 2015, 10:09 AM
somd914   Also, are those posts between the row of cars? If...   Mar 29 2015, 12:06 PM
rhodyguy   No entry door other than the bay doors? The 16x7 n...   Mar 29 2015, 12:10 PM
somd914   Looking at the side elevation, the exterior wall ...   Mar 29 2015, 01:28 PM
Phoenix-MN   Max Jax two post lift, you can set it up/take it d...   Mar 29 2015, 01:47 PM
siverson   Hi - thanks for the input! > You can't...   Mar 29 2015, 08:01 PM
siverson   with 914s for scale -Steve   Mar 29 2015, 08:02 PM
Chris914n6   I just built a 20'x28' Porsche space. Don...   Mar 29 2015, 08:04 PM
Garold Shaffer   I have a midrise lift and works great for dropping...   Mar 29 2015, 08:20 PM
siverson   some photos from today. we are adding the 3 single...   Mar 29 2015, 08:41 PM
siverson   16x7 door   Mar 29 2015, 08:42 PM
siverson   inside   Mar 29 2015, 08:43 PM
siverson   and our current 2 car garage. lots of home depot s...   Mar 29 2015, 08:53 PM
914_teener   and our current 2 car garage. lots of home depot ...   Mar 30 2015, 08:56 AM
siverson   Funny how cars look so much better in photos... I ...   Mar 29 2015, 08:55 PM
eric9144   My space is 32x33, I remeber thinking when we were...   Mar 29 2015, 08:57 PM
Chris914n6   That's one heck of a house project. It will be...   Mar 29 2015, 09:48 PM
siverson   > I.ll store that six in my teener for you whil...   Mar 30 2015, 11:36 AM
siverson   > Sure you can stack cars double deep but you...   Mar 30 2015, 11:37 AM
bigkensteele   Couple of ideas for you to ponder. I built this s...   Mar 30 2015, 07:27 PM
r_towle   One word....dust. Get cabinets with doors for eve...   Mar 30 2015, 07:59 PM
siverson   Some progress and the lift arrived today...   May 9 2015, 01:11 AM
siverson   where the 3 single car garage doors will go.   May 9 2015, 01:13 AM
siverson   914   May 9 2015, 01:14 AM
siverson   lift   May 9 2015, 01:15 AM
somd914   Thanks for the update, I was thinking about your t...   May 9 2015, 06:12 AM
Cairo94507   I am very excited for you in tackling your garage ...   May 9 2015, 10:49 PM
SixerJ   After doing my garage I would consider the followi...   May 19 2015, 05:25 PM
siverson   914   May 27 2015, 08:41 PM
Cairo94507   Very cool :beer2:   May 27 2015, 09:00 PM
siverson   concrete should be poured this week.   May 27 2015, 09:13 PM
siverson   Here are some photos of the area when we first bou...   May 27 2015, 09:31 PM
siverson   Another   May 27 2015, 09:31 PM
siverson   914   May 27 2015, 09:33 PM
siverson   Outside   May 27 2015, 09:33 PM
siverson   footings in. and i made the driveway a little wi...   May 31 2015, 12:17 PM
siverson   914   May 31 2015, 12:18 PM
siverson   914   May 31 2015, 12:21 PM
siverson   914   May 31 2015, 12:22 PM
siverson   am i boring you guys with concrete photos?   Jun 2 2015, 04:33 PM
rhodyguy   I'd like to see the vista from the deck top.   Jun 2 2015, 04:41 PM
siverson   i just decided to move a couple trees and got rid ...   Jun 9 2015, 03:44 PM
siverson   914   Jun 9 2015, 03:45 PM
db9146   The garage is looking great!!! Couple...   Jun 9 2015, 04:36 PM
Cairo94507   Oh heck no! For me, I love watching cement wo...   Jun 9 2015, 05:40 PM
bandjoey   don't forget the LAN wires for hot internet ac...   Jun 9 2015, 07:48 PM
Philip W.   is that earthquake resistant concrete? :poke:   Jun 10 2015, 09:55 AM
siverson   > don't forget the LAN wires for hot intern...   Jun 24 2015, 11:11 PM
siverson   A visitor... -Steve   Jun 24 2015, 11:15 PM
siverson   Framing   Jun 24 2015, 11:16 PM
siverson   914   Jun 24 2015, 11:18 PM
PlantMan   914 Who is responsible for the artwork left of t...   Jun 24 2015, 11:35 PM
siverson   Stucco   Jun 24 2015, 11:19 PM
siverson   > Who is responsible for the artwork left of th...   Jun 25 2015, 12:49 AM
RobW   Nice work! :first:   Jun 25 2015, 06:52 AM
Cairo94507   Very cool - looking nice.   Jun 25 2015, 06:55 AM
rhodyguy   smart move straightening out the stone retaining w...   Jun 25 2015, 06:58 AM
siverson   yup i have tried to save the persimmon tree but we...   Jun 27 2015, 12:52 AM
rhodyguy   try Liquinox B-1 transplant solution as per the in...   Jun 27 2015, 08:38 AM
siverson   Slow progress (more on the house), but drywall wen...   Jul 13 2015, 10:47 PM
siverson   914   Jul 13 2015, 10:47 PM
siverson   Concrete this week... ?!?! (was supposed t...   Jul 13 2015, 10:48 PM
Maltese Falcon   Make sure that the sealed deck above your garage i...   Jul 14 2015, 12:23 AM
siverson   texture, stone, getting ready to pour driveway   Jul 22 2015, 07:47 PM
siverson   914   Jul 22 2015, 07:48 PM
siverson   914   Jul 22 2015, 07:51 PM
Cairo94507   Making very nice progress. I remember in my las...   Jul 22 2015, 09:17 PM
siverson   rebar   Aug 4 2015, 03:02 PM
siverson   concrete   Aug 4 2015, 03:04 PM
rhodyguy   That's a large amount of flat work! Looks ...   Aug 4 2015, 03:07 PM
eric9144   Damn that's looking great! You've got...   Aug 4 2015, 04:46 PM
siverson   > You've got to be exited as heck to be nea...   Aug 4 2015, 06:53 PM
siverson   no garage doors (problem with order), still a ton ...   Aug 9 2015, 07:32 PM
mepstein   Very nice! Enjoy.   Aug 9 2015, 07:45 PM
JmuRiz   B-ball goal is so low, the 914 can dunk on it :) ...   Aug 9 2015, 07:51 PM
rhodyguy   Congrats! The low aspect of the bed stones is ...   Aug 9 2015, 08:01 PM
Cairo94507   Very exciting- congratulations.   Aug 9 2015, 10:15 PM
siverson   > the 914 can dunk on it And so can my 6yo...   Aug 10 2015, 02:21 PM
KELTY360   Man, that concrete looks so pristine. Do you scree...   Aug 10 2015, 05:02 PM
siverson   lift   Aug 23 2015, 07:35 PM
siverson   914   Aug 23 2015, 07:35 PM
euro911   Nice garage, Steve! :drooley: I'll be g...   Aug 23 2015, 11:36 PM
siverson   geez i hate unpacking. for those of you that move ...   Oct 3 2015, 12:25 AM
siverson   914   Oct 3 2015, 12:26 AM
siverson   914   Oct 3 2015, 12:27 AM
euro911   :drooley:   Oct 3 2015, 02:00 AM
rhodyguy   You sprung for the fancy liftmaster door openers. ...   Oct 3 2015, 06:44 AM
Cairo94507   Congratulations. I love the lift in the center st...   Oct 3 2015, 07:42 AM
siverson   > You sprung for the fancy liftmaster door open...   Oct 3 2015, 08:54 AM
rhodyguy   The relatively small price dif compared to chain o...   Oct 3 2015, 09:03 AM
- Lo-Fi Version Time is now: 1st August 2025 - 05:25 PM
