Questions About 912E Cars |
Larmo63 |
May 18 2015, 11:39 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I have a track on a clean 912E. I know these cars are bastards, but what is the market and current opinion on worth and collectibility?
Thanks…! |
Bulldog9 |
May 22 2015, 07:24 AM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I've got #770, and happy to have it. Almost passed on it when I found it due to being the 911 with a VW motor, but a few minutes of web searching I discovered it is likely the best of the mid year N/A 911's, at least best for me. Light weight, better balanced than the 911, galvanized bodies (1st year) Type 4 motor is easy to service, maintain and rebuild, decent fuel mileage.
As others mentioned, is basically a 76 911S with a modified 2.0 914 Motor with different fuel injection and Thermal reactors. I'm in the final stages of a total gut and rebuild, and other than a few things beyond the engine and trans gearing, the car is a low content barebones 76 911s. The other Main differences I have found are: - Different ratios in Transmission, with smaller input shaft and strange 914/911 clutch/throwout bearing setup. - Stock brakes are solid disks front and rear - No Stock fog lights or wiring - Skinny tires/Rims - Different shock/strut inserts - Smaller front and no rear sway bar - Fixed rear windows (pop out was an aftermarket add on) - No passenger side mirror As far as value, according to Haggerty, the value has tripled in the last 3 years, which helps to keep SWMBO (she who must be obeyed) off my back (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/drooley.gif) The 912E will likely never pull the same price as a 76 911, but is increasing in price, and as others have said, the upcoming release of 4cyl Porsches may remind others that there was once a 4cyl 911 called the 912. My guess is that despite its limited number, due to the Type 4, the 912E will always be the low priced option. But I don't buy cars for the 'collectability' I buy what I love and keep it. I've never lost money, but neither can I retire on that 'collectible.' I will be sending back to Scotty B for the headliner, windscreens and a few other things I don't have the skill to do. You can check out the #770 thread to see my bumbling over the last few years. I'm in the military so get bounced around every 3-4 years, but have registered the car as an antique in my home of record state, so the car will never see another inspection station. Is this not an option for all states? I know CA is a lost cause, but what about the rest? |
mepstein |
May 22 2015, 12:53 PM
914-6 GT in waiting Group: Members Posts: 19,312 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I've got #770, and happy to have it. Almost passed on it when I found it due to being the 911 with a VW motor, but a few minutes of web searching I discovered it is likely the best of the mid year N/A 911's, at least best for me. Light weight, better balanced than the 911, galvanized bodies (1st year) Type 4 motor is easy to service, maintain and rebuild, decent fuel mileage. As others mentioned, is basically a 76 911S with a modified 2.0 914 Motor with different fuel injection and Thermal reactors. I'm in the final stages of a total gut and rebuild, and other than a few things beyond the engine and trans gearing, the car is a low content barebones 76 911s. The other Main differences I have found are: - Different ratios in Transmission, with smaller input shaft and strange 914/911 clutch/throwout bearing setup. - Stock brakes are solid disks front and rear - No Stock fog lights or wiring - Skinny tires/Rims - Different shock/strut inserts - Smaller front and no rear sway bar - Fixed rear windows (pop out was an aftermarket add on) - No passenger side mirror As far as value, according to Haggerty, the value has tripled in the last 3 years, which helps to keep SWMBO (she who must be obeyed) off my back (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/drooley.gif) The 912E will likely never pull the same price as a 76 911, but is increasing in price, and as others have said, the upcoming release of 4cyl Porsches may remind others that there was once a 4cyl 911 called the 912. My guess is that despite its limited number, due to the Type 4, the 912E will always be the low priced option. But I don't buy cars for the 'collectability' I buy what I love and keep it. I've never lost money, but neither can I retire on that 'collectible.' I will be sending back to Scotty B for the headliner, windscreens and a few other things I don't have the skill to do. You can check out the #770 thread to see my bumbling over the last few years. I'm in the military so get bounced around every 3-4 years, but have registered the car as an antique in my home of record state, so the car will never see another inspection station. Is this not an option for all states? I know CA is a lost cause, but what about the rest? PA does a $75 one time fee for reg and no inspection for antique. It makes our cars very economical to own and easy to have more than 1. Non op fee doesn't exist either. |
Lo-Fi Version | Time is now: 5th June 2024 - 09:32 AM |
