74 2.0 F.I. NO spark, Ran before new battery |
Nemisus |
May 17 2015, 02:14 PM
Member Group: Members Posts: 82 Joined: 1-October 11 From: North Bay CA Member No.: 13,631 Region Association: Northern California |
So I am stumped. When I took delivery of my newly acquired 74 914 the car would start up just fine with a jump box.
I went out and bought a new battery and now I have no spark... at lest from I can tell doing the simple spark tests I have done. I just did an Ohms test on my Ignition coil and here is what I got Primary: 1.4 Secondary: 10.41 Per the Pelican Technical Article I should see readings like this: primary coil winding's should give a reading of 0.3-0.6 ohms. Secondary coils should be near 600 ohms. If I understand my results I am significantly higher than where I should be? But does that mean my coil is is the cause of no spark. The only thing I changed was a busted fuel line and put in a new battery... Now the car will not start. Any ideas on where else to look? Thanks in advance Cheers Nem |
stugray |
May 24 2015, 11:44 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Notes from my plugs research:
NGK BP6ES voted best plug for 914 (per Cap'n Krusty): http://www.914world.com/bbs2/index.php?showtopic=217463 BOSCH W7CC for carbs (then adjust heat range based on particular engine). Reputable local 914 racer says you can use the Bosch 4 prong plugs #4417 but I havent tried them yet. |
Dave_Darling |
May 24 2015, 04:44 PM
BOSCH W7CC for carbs (then adjust heat range based on particular engine). Also for D-jet. QUOTE Reputable local 914 racer says you can use the Bosch 4 prong plugs #4417 but I havent tried them yet. As far as I can tell, those are the same crappy platinum plugs with three extra electrodes welded on. Still crap IMHO. The cheap Bosch Platinum plugs that you can get everywhere are pretty lousy. There are some very expensive ones that are hard to find that have a solid platinum electrode, as opposed to the little speck the cheapies have. --DD |
Lo-Fi Version | Time is now: 9th June 2024 - 12:31 PM |
