> Setrab oil cooler, Can two small ones be run in series?
rtalich
post May 22 2015, 07:50 PM
Ordered the smaller setrab unit with fan to replace the oil cooler that was installed when I bought the car (pictures). The new setrab unit is way smaller than I thought it would be. In fact, it's about half the size of what's installed now. I'm pretty sure the bigger setrab unit with the double fans is too big for this space. Anyone see issues if I run two of these smaller units in series? That way I can install them staggered and will fit in that space quite nicely.
VaccaRabite
post May 24 2015, 04:54 PM
En Garde!
Dual SETRAB unit DOES fit in the same location that you want to put yours.
Proof:
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-1435-1432508090.1.jpg)
In this pic I have headers, but they also fit just fine here with SSI heat exchangers and a muffler. Also keeps oil temps low. Mine went from ~240 to 205. Mine is themostat controlled, with the stat opening and the fans turning on at 180.
Zach
rtalich   Setrab oil cooler   May 22 2015, 07:50 PM
jim_hoyland   Interesting.. would a space between the trunk and ...   May 22 2015, 07:54 PM
McMark   Yes, but running them in parallel is better.   May 22 2015, 08:12 PM
rtalich   Yes, but running them in parallel is better. Co...   May 22 2015, 08:28 PM
screenguy914   Yes, but running them in parallel is better. Yo...   May 22 2015, 09:11 PM
stugray   Yes, but running them in parallel is better. Y...   May 22 2015, 09:42 PM
Andyrew   [quote name='screenguy914' post='2190229' date='M...   May 26 2015, 01:17 PM
stugray   Stu, You got pics of this? I am curious of the...   Jun 14 2015, 01:03 PM
bdstone914   Yes, but running them in parallel is better. :a...   May 23 2015, 06:27 AM
Porschef   I'm very pleased with the performance of the s...   May 22 2015, 08:27 PM
Porschef   If 220 is the highest temp your seeing, one of the...   May 22 2015, 08:51 PM
patssle   It keeps my six cool with just one. (not braced in...   May 22 2015, 09:04 PM
aircooledtechguy   Those coolers work so well, I doubt you will need ...   May 22 2015, 11:27 PM
McMark   Oil cooling works best when there is a large diffe...   May 23 2015, 02:18 AM
SLITS   If Jim Lamonica (six here) would post, he runs two...   May 23 2015, 07:46 AM
Jake Raby   For a good oil, 230 isn't hot and some oils pr...   May 23 2015, 09:12 AM
Vacca Rabite   Dual SETRAB unit DOES fit in the same location tha...   May 24 2015, 04:54 PM
Elliot Cannon   Dual SETRAB unit DOES fit in the same location th...   Jun 14 2015, 12:03 PM
rtalich   Thanks for all the comments and suggestions! ...   May 26 2015, 09:09 AM
rtalich   Just a quick update. I finally installed the setra...   Jun 14 2015, 11:51 AM
Mike Bellis   That's a cross flow cooler. Supposed to have m...   Jun 14 2015, 11:54 AM
Andyrew   /\ I agree, turn the cooler so you can see it...   Jun 14 2015, 12:01 PM
bdstone914   In referance to posts #18 and #19: Yes that is a ...   Jun 14 2015, 12:08 PM
rtalich   Thanks guys!! I will be driving it this we...   Jun 14 2015, 12:19 PM
rtalich   Well... It was pretty warm today... 80 degrees out...   Jun 15 2015, 06:26 PM
Philip W.   Well... It was pretty warm today... 80 degrees ou...   Jun 16 2015, 06:58 AM
stugray   Well... It was pretty warm today... 80 degrees ou...   Jun 16 2015, 07:59 AM
era vulgaris   Not the best pic, but the only one I have of my se...   Jun 16 2015, 08:26 AM
Dave_Darling   I actually need to figure out a way to get my oil...   Jun 16 2015, 11:39 AM
era vulgaris   I actually need to figure out a way to get my oi...   Jun 16 2015, 11:53 AM
SLITS   [quote name='Dave_Darling' post='2199339' date='J...   Jun 16 2015, 02:00 PM
maf914   Setrab oil cooler with a pair of 5" Spal pu...   Jun 17 2015, 07:22 AM
era vulgaris   [quote name='era vulgaris' post='2199296' date='J...   Jun 17 2015, 11:53 AM
JmuRiz   Cool setup, I was thinking of doing an NACA duct o...   Jun 16 2015, 10:22 AM
era vulgaris   Cool setup, I was thinking of doing an NACA duct ...   Jun 16 2015, 11:08 AM
rtalich   Another warm day on the way home from work. Helps ...   Jun 16 2015, 06:05 PM
McMark   :trophy:   Jun 16 2015, 09:06 PM
Philip W.   how are you tapping the new oil lines to the new c...   Jun 17 2015, 01:06 PM
era vulgaris   how are you tapping the new oil lines to the new ...   Jun 17 2015, 03:45 PM
Vacca Rabite   Ohhh. I like that! Is it also full flow? Z...   Jun 17 2015, 06:48 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:20 PM
