Zambesi car lives, and then dies |
peridotian |
Sep 8 2004, 09:28 AM
Unregistered |
So I bought a 78 911 SC this weekend that is total CREAMPUFF and therefor decided to sell the $2000 74 Green car to my son (HE'S STOKED!). The 914 however has problems. The deal with the 914 seller was I would bring a battery and if it started and did not have rod knock, blue smoke, grinding tranny etc, than we would complete the deal. The car started right up but was spewing fuel. We found the fuel leak, fixed it and tried to fire again. No power to Gages and no noise from starter. But there was a wierd noise fromk under the passenger seat. Unbolt seat and there is a couple of highly corroded modules, cut wires, corrosion both green and brown everywhere. One of the modules (Bosch logic?) has about 10 terminals on it and is the one that vibrates with the key on albeit half heartedly. There is a culrlicue wire running into the seat bottom on the pass side. Did I get heated seats? Can I just rip all the seat buzzer and related stuff out? Will the seat buzzer circuit being corroded cause a no start problem?
ArtechnikA |
Sep 8 2004, 09:36 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
i'm confused - is the corroded stuff under the pax seat in the 911 or the 914 ? your post makes it sound like you're having issues with the 911, and if that's the case, 914-oriented fixes don't apply.
MikeZ has an early SC so maybe he's seen some of that stuff; MarkB too i think. if it *is* the 911 you're dealing with, let me suggest you join RennList's 911 List; they've helped me a lot... |
Lo-Fi Version | Time is now: 11th June 2024 - 12:19 AM |
