| r_towle |
Apr 27 2014, 01:26 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Does anyone know of a vendor that could take a set of stock 4 bolt Fuchs and either make them wider by welding on a wider outer area, or could cut out the middle to make up a custom 3 piece wheel?
Rich |
| r_towle |
Apr 28 2014, 10:22 AM
so,
Before I venture down this road.... What size rubber can be put on an 8 inch wheel? Just want to make sure I can actually buy tires when I am all done. so 8 by 15.... I know I can get Hooziers....so that is covered. How about street rubber? What is the widest or range? I got on tire rack and got stuck in the definitions of all the numbers...walked away knowing less and was far more confused.... Rich |
| 914_3.0 |
Jun 3 2015, 05:30 PM
Newbie ![]() Group: Members Posts: 49 Joined: 8-January 14 From: Central Cal Coast Member No.: 16,856 Region Association: Central California |
so, Before I venture down this road.... What size rubber can be put on an 8 inch wheel? Just want to make sure I can actually buy tires when I am all done. so 8 by 15.... I know I can get Hooziers....so that is covered. How about street rubber? What is the widest or range? I got on tire rack and got stuck in the definitions of all the numbers...walked away knowing less and was far more confused.... Rich I just got my setup on. 5-lug Fuchs: 7x15 front, 8x15 rear. Square tire setup: Toyo Proxes RR 225/45-15. It's flared, and I'm using a 1" spacer. |
r_towle Custom three piece wheels Apr 27 2014, 01:26 PM
Krieger I have seen wheels that Harvey Weidman widened. H... Apr 27 2014, 01:33 PM
r_towle
I have seen wheels that Harvey Weidman widened. ... Apr 27 2014, 02:24 PM
bulitt Sounds like a Dave Darling Question... Apr 27 2014, 01:40 PM
Woody Rebel racing does it with 5 lug Fuchs. Bring money... Apr 27 2014, 03:10 PM
sixnotfour I can and have done quite a few fuchs centered 17... Apr 27 2014, 03:18 PM
sixnotfour :beer2:
15x6.5 Mahle gas burner 5 lug
15x7 Mahle ... Apr 27 2014, 03:25 PM
sixnotfour :beer2:
9x17 Fuchs
11x17 Fuchs Apr 27 2014, 03:29 PM
r_towle Sixnotfour,
How does the center of the 4 lug faux... Apr 27 2014, 03:34 PM
sixnotfour Yes, They are interference fit and tig welded on t... Apr 27 2014, 06:20 PM
r_towle
Yes, They are interference fit and tig welded on ... Apr 27 2014, 08:04 PM
Mueller
Yes, They are interference fit and tig welded on ... Jun 3 2015, 03:48 PM
Mike Bellis This place is the cheapest I found. I plan to use ... Apr 27 2014, 07:24 PM
sixnotfour what widths do you want ?? Yes I do them on a limi... Apr 27 2014, 09:02 PM
r_towle
what widths do you want ?? Yes I do them on a lim... Apr 27 2014, 09:35 PM
rick 918-S I got your PM Jeff. Call me about the Enkei 92... Apr 27 2014, 09:21 PM
Woody What size? Tires that will fit a 15x9 are becomes ... Apr 27 2014, 09:45 PM
r_towle
What size? Tires that will fit a 15x9 are becomes... Apr 28 2014, 08:19 AM
peteyd These guys also can widen your rims.
http://www.l... Apr 28 2014, 08:17 AM
Chris H. Reminds me of those 8" Pedrinis that floated ... Apr 28 2014, 08:52 AM
Chris H. Nother pic...
Apr 28 2014, 08:55 AM
rick 918-S
Nother pic...
Here they are!
http://www... Apr 29 2014, 11:49 AM
sixnotfour TRUDESIGN WHEEL, INC.
Porsche Alloy Fuchs wheel re... Apr 28 2014, 09:24 AM
patrick3000
so,
What si... Apr 28 2014, 10:49 AM
matthepcat I had a pare of custom wheels from a company in th... Jun 3 2015, 03:56 PM
Mueller
I had a pare of custom wheels from a company in t... Jun 3 2015, 04:21 PM
r_towle
[quote name='matthepcat' post='2194568' date='Jun... Jun 3 2015, 04:26 PM
Mueller
[quote name='matthepcat' post='2194568' date='Ju... Jun 3 2015, 04:32 PM
stugray
Bummer, my lathe only has a 13" diameter cl... Jun 3 2015, 05:13 PM
r_towle
[quote name='r_towle' post='2194578' date='Jun 3 ... Jun 3 2015, 05:28 PM
7TPorsh Just noticed this thread. I recently found out my... Jun 3 2015, 04:24 PM
Mueller
Just noticed this thread. I recently found out m... Jun 3 2015, 04:31 PM
stugray
Just noticed this thread. I recently found out m... Jun 3 2015, 04:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:27 PM |
