Temperature in front trunk with radiator??, anyone run before and after tests?? |
Mueller |
Sep 8 2004, 11:48 PM
just wondering how darn hot does it get up in there????
could the fuel be heated up enough to cause vapor lock more readily?? (this I doubt, but had to ask (IMG:style_emoticons/default/smile.gif) ) |
Howard |
Sep 9 2004, 12:16 AM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Hey, I can finally answer a question (IMG:style_emoticons/default/smilie_pokal.gif)
Have front and rear coolant temp gauges on the V8. Front sensor at point where coolant leaves to return to engine, rear in cylinder head at last exhaust port where it returns to radiator. Normal ops: front: 165 rear: 210 Hot (uphill Mulholland fast clip 100 ambient) : front: 235 rear: 190 Will overfill 1 quart puke tank when running hot, so will go to 1 gallon if it will fit. Fuel tank will become warm to touch, but don't believe it's enough to cause a problem. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:10 PM |
