| boxsterfan |
Jun 7 2015, 10:30 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Has anyone ever tried to customize their 914 with a climate control system from a 993, 996 or Boxster? One thing I am dreading when putting my car back together is getting that push/pull cable system back into the car.
Would it even be reasonably possible? Note: No A/C in the car, so maybe buttons there but non-functional. A 993 climate control looks suitable from a "looks" point of view, but no doubt big $$$. http://rennlist.com/forums/attachments/993...-canon-2220.jpg Ignore the whole carbon fiber bits....just the climate control would be desired. |
| Mike Bellis |
Jun 7 2015, 10:38 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
If it were possible, it would take serious engineering. Most likely they are servo motor controlled. So you would need a controller to run a linear actuator the the 914 flaps.
Sounds way easier to install the 914 cables. |
| boxsterfan |
Jun 7 2015, 11:49 PM
If it were possible, it would take serious engineering. Most likely they are servo motor controlled. So you would need a controller to run a linear actuator the the 914 flaps. Sounds way easier to install the 914 cables. I would still control the flaps (and blower) in back by the HE's by hand (el manual). Actually, I can't remember is the lever for heat in the 914 turns on the blower in the back or not. And reading up on it, they had 993 Climate Control Units that is are non-AC. Seems like you need the fan switch on the 993 CCU to turn on the blower up front. You need the CCU hooked up to an "air box" up front with a servo motor to control feet/defrost or both for direction of the air. I'd live with just defrost personally. It's not like the 914 cabin is a monstrous cabin to heat. And there is always seat heaters... (IMG:style_emoticons/default/idea.gif) Nothing wrong with a little serious engineering. |
boxsterfan Customizing dashboard heater/defrost controls Jun 7 2015, 10:30 PM
Mueller http://www.surpluscenter.com/shop.axd/Search?keywo... Jun 7 2015, 11:36 PM
r_towle just man up and put it all back in the right way.
... Jun 8 2015, 11:25 AM
Andyrew Im going to be incorporating a early 2000's Au... Jun 8 2015, 12:53 PM
boxsterfan
Im going to be incorporating a early 2000's A... Jun 8 2015, 02:10 PM
Andyrew Well I am going to be building an entirely new das... Jun 8 2015, 02:36 PM
Mike Bellis The CCU will require the CAN bus to operate proper... Jun 8 2015, 02:41 PM
Andyrew ^This was my thought as well.
I dont think its a... Jun 8 2015, 03:04 PM
boxsterfan I'm not even trying to achieve automated Clima... Jun 8 2015, 03:59 PM
Andyrew Maybe you could get a 944 unit to work?
http://w... Jun 8 2015, 05:15 PM
boxsterfan Well, I found a 986 Boxster air distribution unit ... Jun 9 2015, 04:52 PM
Mike Bellis Read up on the CAN bus and error codes. Many modul... Jun 9 2015, 06:52 PM
boxsterfan
Read up on the CAN bus and error codes. Many modu... Jun 9 2015, 08:05 PM
Mike Bellis
Read up on the CAN bus and error codes. Many mod... Jun 9 2015, 09:23 PM
Andyrew
[quote name='boxsterfan' post='2196989' date='Jun... Jun 9 2015, 10:04 PM
boxsterfan Looks like Porsche did not implement a CAN bus on ... Jun 9 2015, 09:45 PM
boxsterfan https://www.diyautotune.com/product/ms3pro-...agem... Mar 21 2017, 10:00 PM
Elliot Cannon I have no use for a linear actuator. I just like ... Mar 21 2017, 10:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd April 2026 - 06:08 AM |
