| Cfletch |
Jun 8 2015, 10:37 PM
Member ![]() ![]() Group: Members Posts: 259 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
Looking for a Ignition CM for my 1974 2.7l engine. I see the MSD 6201 Digital 6A on pelican and I am wondering if i'll run into any issues with that, and also what else would I need?
| MJHanna |
Jun 9 2015, 09:37 AM
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
I think I'll go with that unit I mentioned. Do you have the coil part number? And with the cd and the new coil I should be ok as far as ignition correct? Why? Why would you not want to take advantage of having a soft rev limiter? Just wait until you over shift and are replacing values and doing a top end on your 2.7. you might wished bought one that had that feature. (IMG:style_emoticons/default/dry.gif) You can have issues with the sparkplug wires, and as mentioned you could have issues with the tach working correctly if you use a VDO. |
| Cfletch |
Jun 9 2015, 10:06 AM
I think I'll go with that unit I mentioned. Do you have the coil part number? And with the cd and the new coil I should be ok as far as ignition correct? Why? Why would you not want to take advantage of having a soft rev limiter? Just wait until you over shift and are replacing values and doing a top end on your 2.7. you might wished bought one that had that feature. (IMG:style_emoticons/default/dry.gif) You can have issues with the sparkplug wires, and as mentioned you could have issues with the tach working correctly if you use a VDO. Because according to Mark the model mentioned has a limiter. |
| Mark Henry |
Jun 9 2015, 11:17 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Because according to Mark the model mentioned has a limiter. You said MSD 6201 Digital 6A, I said MSD 6AL which is model #6425. Model 6201 I don't see a mention of a rev limiter. Why? Why would you not want to take advantage of having a soft rev limiter? Just wait until you over shift and are replacing values and doing a top end on your 2.7. you might wished bought one that had that feature. In a real bad missed shift a rev limiter is NOT going to save you, as that is a mechanical over rev. In the same vane you should never use a rev limiter as a shift indicator. I don't care if they call it a "soft" limiter you are still loading and unloading the engine at high RPM. A rev limiter is a safety device, but never think it's fool proof. |
Cfletch Ignition wiring Jun 8 2015, 10:37 PM
matthepcat You can run an old Bosh CDI with a basic coil. Run... Jun 9 2015, 12:03 AM
Mark Henry MSD 6AL now has a rev limiter built in, no more pi... Jun 9 2015, 06:06 AM
MJHanna Also look at the MSD streetfire.
http://www.msdp... Jun 9 2015, 06:34 AM
Cfletch I think I'll go with that unit I mentioned. Do... Jun 9 2015, 08:36 AM
Cfletch
Because according to Mark the model mentioned h... Jun 9 2015, 01:36 PM
sixnotfour MSD Digital 6A and 6AL Ignition Control
6A - PN 62... Jun 9 2015, 11:34 AM
MJHanna
Because according to Mark the model mentioned h... Jun 9 2015, 12:41 PM
screenguy914 I think it's as important to ditch the factory... Jun 9 2015, 07:15 PM
Cfletch
I think it's as important to ditch the factor... Jun 9 2015, 08:37 PM
Cfletch So I got my parts today, Im running the MSD 6AL wi... Jun 11 2015, 09:04 PM
Mark Henry The diagram is correct, the pertronix coil wires n... Jun 12 2015, 09:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th November 2026 - 12:58 PM |
