| boxsterfan |
Jun 7 2015, 10:30 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Has anyone ever tried to customize their 914 with a climate control system from a 993, 996 or Boxster? One thing I am dreading when putting my car back together is getting that push/pull cable system back into the car.
Would it even be reasonably possible? Note: No A/C in the car, so maybe buttons there but non-functional. A 993 climate control looks suitable from a "looks" point of view, but no doubt big $$$. http://rennlist.com/forums/attachments/993...-canon-2220.jpg Ignore the whole carbon fiber bits....just the climate control would be desired. |
| Mike Bellis |
Jun 9 2015, 06:52 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Read up on the CAN bus and error codes. Many modules will not work without an "OK" signal from the master (dash cluster).
I have dealt a lot with CAN on my conversion. I still get an error from the missing ABS controller. I am running the dash cluster and ECU. the two work well together. The ABS will eventually get flashed out. I don't think you will get the CCU to work unless you can hack the CAN signal and write code. |
| boxsterfan |
Jun 9 2015, 08:05 PM
Read up on the CAN bus and error codes. Many modules will not work without an "OK" signal from the master (dash cluster). I have dealt a lot with CAN on my conversion. I still get an error from the missing ABS controller. I am running the dash cluster and ECU. the two work well together. The ABS will eventually get flashed out. I don't think you will get the CCU to work unless you can hack the CAN signal and write code. Fortunately, the interwebs might be of help. http://www.instructables.com/id/Hack-your-...no-and-Seeed-C/ Plus, I can code. :-) |
| Mike Bellis |
Jun 9 2015, 09:23 PM
Read up on the CAN bus and error codes. Many modules will not work without an "OK" signal from the master (dash cluster). I have dealt a lot with CAN on my conversion. I still get an error from the missing ABS controller. I am running the dash cluster and ECU. the two work well together. The ABS will eventually get flashed out. I don't think you will get the CCU to work unless you can hack the CAN signal and write code. Fortunately, the interwebs might be of help. http://www.instructables.com/id/Hack-your-...no-and-Seeed-C/ Plus, I can code. :-) Looks promising! I might need these parts... |
boxsterfan Customizing dashboard heater/defrost controls Jun 7 2015, 10:30 PM
Mike Bellis If it were possible, it would take serious enginee... Jun 7 2015, 10:38 PM
boxsterfan
If it were possible, it would take serious engine... Jun 7 2015, 11:49 PM
Mueller http://www.surpluscenter.com/shop.axd/Search?keywo... Jun 7 2015, 11:36 PM
r_towle just man up and put it all back in the right way.
... Jun 8 2015, 11:25 AM
Andyrew Im going to be incorporating a early 2000's Au... Jun 8 2015, 12:53 PM
boxsterfan
Im going to be incorporating a early 2000's A... Jun 8 2015, 02:10 PM
Andyrew Well I am going to be building an entirely new das... Jun 8 2015, 02:36 PM
Mike Bellis The CCU will require the CAN bus to operate proper... Jun 8 2015, 02:41 PM
Andyrew ^This was my thought as well.
I dont think its a... Jun 8 2015, 03:04 PM
boxsterfan I'm not even trying to achieve automated Clima... Jun 8 2015, 03:59 PM
Andyrew Maybe you could get a 944 unit to work?
http://w... Jun 8 2015, 05:15 PM
boxsterfan Well, I found a 986 Boxster air distribution unit ... Jun 9 2015, 04:52 PM
Andyrew
[quote name='boxsterfan' post='2196989' date='Jun... Jun 9 2015, 10:04 PM
boxsterfan Looks like Porsche did not implement a CAN bus on ... Jun 9 2015, 09:45 PM
boxsterfan https://www.diyautotune.com/product/ms3pro-...agem... Mar 21 2017, 10:00 PM
Elliot Cannon I have no use for a linear actuator. I just like ... Mar 21 2017, 10:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd April 2026 - 06:18 AM |
