Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
Mike Bellis |
Jun 13 2015, 08:42 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Verifying the entire systems can take several days/weekends. It's most challenging with color blindness. Sounds like you need a build party! (IMG:style_emoticons/default/piratenanner.gif)
Or, I can wait until you are totally frustrated and buy the car off you super cheap... (IMG:style_emoticons/default/happy11.gif) |
Andyrew |
Jun 13 2015, 08:48 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Or, I can wait until you are totally frustrated and buy the car off you super cheap... (IMG:style_emoticons/default/happy11.gif) That was the plan I had with your car.... (IMG:style_emoticons/default/chowtime.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:47 AM |
