> Found after motor back in
last337
post Jun 14 2015, 02:20 PM
Of course as soon as I get the motor back in I look in toolbox and see a few bolts and nuts sitting there, staring at me. I have been staring at all visible areas and I am at a loss. Thought maybe someone might have an idea based on what I have done:
Pulled motor
Removed all tin, impeller housing pieces, alternator mount
Impeller
Oil cooler (replaced seals)
Transmission separated
flywheel/clutch removed
I did all the above over a year ago when I started fixing hellhole and longs and took apart more than I needed but used chance to clean everything thoroughly
So I have what looks to be the following left:
three M8 x 40 bolts
three A8 spring washers
two M8 x 20 bolts and matching M8 nuts
I was a bit worried they were for impeller (only place I remember 3 bolts) but I remember putting those on. I dont recall putting the M8x20's back into the oil cooler brackets so that might account for those two but leaves me with a really odd number of things left. I also dont remember using anything on shroud/tin but the 4 nuts and spring washers that hold it to the front of the motor.
I am really kickin myself over this and I know I could easily take it all apart and still not find any spots for these. I have been going through exploded diagrams and just lost. Its possible these were from somewhere else in engine bay or maybe even just floating in car when I got it but it was too long ago even as organized as I tried to be with it.
Any help or suggestions are appreciated
last337
post Jun 15 2015, 07:50 AM
Thanks for the replies. I still cant find anyone where those M8x40's would go.
At this point the motor is back in and just about ready to light up. Part of me wants to pull it all apart again but who knows where they go.
I suppose I will find out if they are missing from somewhere soon enough!
What would you do?
last337   Found after motor back in   Jun 14 2015, 02:20 PM
arkitect   Maybe you replaced them with new? and they are ext...   Jun 14 2015, 02:44 PM
last337   I wish that was the case but I only bought new mot...   Jun 14 2015, 03:17 PM
914Mike   I wish that was the case but I only bought new mo...   Jun 14 2015, 04:44 PM
last337   I wish that was the case but I only bought new m...   Jun 14 2015, 05:09 PM
wndsnd   Not rusty. Sure they came from your 914?   Jun 14 2015, 05:33 PM
rmital   Not rusty. Sure they came from your 914? :agre...   Jun 15 2015, 08:16 AM
Dave_Darling   Engine tin is almost all M6. There is one M8 fast...   Jun 14 2015, 07:24 PM
last337   Thanks for the replies. I still cant find anyone ...   Jun 15 2015, 07:50 AM
mbseto   I know if I get miffed at a car buddy, I'll go...   Jun 15 2015, 08:12 AM
nathansnathan   The only place the pet list 8 x 40 is the upper an...   Jun 15 2015, 09:00 AM
last337   The only place the pet list 8 x 40 is the upper a...   Jun 15 2015, 09:49 AM
SLITS   #15 holds the blower housing halves together (peri...   Jun 15 2015, 11:01 AM
nathansnathan   http://www.porsche.com/all/media/pdf/origi...914_K...   Jun 15 2015, 05:48 PM
last337   I measured them and sure enough they are M8x30s. ...   Jun 15 2015, 07:31 PM
falcor75   I've got a similar but opposite issue...I have...   Jun 15 2015, 11:12 PM
larss   I've got a similar but opposite issue...I hav...   Jun 16 2015, 11:44 AM
crash914   bolts to hold on the fan? uses 3 m8's   Jun 16 2015, 02:56 AM
falcor75   The fan bolts are much longer, something like 45 o...   Jun 16 2015, 05:20 AM
nathansnathan   Yeah, the bolts to hold the fan to the fan hub are...   Jun 16 2015, 07:25 AM
- Lo-Fi Version Time is now: 1st August 2025 - 02:52 AM
