last337 |
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None ![]() |
Of course as soon as I get the motor back in I look in toolbox and see a few bolts and nuts sitting there, staring at me. I have been staring at all visible areas and I am at a loss. Thought maybe someone might have an idea based on what I have done:
Pulled motor Removed all tin, impeller housing pieces, alternator mount Impeller Oil cooler (replaced seals) Transmission separated flywheel/clutch removed I did all the above over a year ago when I started fixing hellhole and longs and took apart more than I needed but used chance to clean everything thoroughly So I have what looks to be the following left: three M8 x 40 bolts three A8 spring washers two M8 x 20 bolts and matching M8 nuts I was a bit worried they were for impeller (only place I remember 3 bolts) but I remember putting those on. I dont recall putting the M8x20's back into the oil cooler brackets so that might account for those two but leaves me with a really odd number of things left. I also dont remember using anything on shroud/tin but the 4 nuts and spring washers that hold it to the front of the motor. I am really kickin myself over this and I know I could easily take it all apart and still not find any spots for these. I have been going through exploded diagrams and just lost. Its possible these were from somewhere else in engine bay or maybe even just floating in car when I got it but it was too long ago even as organized as I tried to be with it. Any help or suggestions are appreciated ![]() |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
The only place the pet list 8 x 40 is the upper and lower front sway bar and to hold the bumpers on.
The 8 x 20, there is 1 in the parking brake lever, 2 holding the alternator swivel bracket to the shroud, 1 for the oil cooler bracket to the shroud, and the 8 that hold the mounts for the engine and transmission (2 bolts per mount, 2 mounts for the engine, 2 for the transmission). If you open the pet in acrobat, and hit ctrl + f and search for "8 x 40" and "8 x 20" those are your only options. |
Lo-Fi Version | Time is now: 1st August 2025 - 02:55 AM |
