> Suddeny it wont run, This car is getting the better of me
DavidSweden
post Jun 13 2015, 06:59 AM
Went out for a short drive this morning. When I got back I parked up the car and shut of the engine. A few minutes later when I should start her up I had difficulty getting her going, the engine started but misfired badly. It then cut out and refuses to start. I have a Petronix but there is a spark. Any ideas on where to start?
Thanks
post Jun 13 2015, 12:03 PM
Resident German
Stock D-Jet? If so, check the CHT, the wire may have come lose ...
Bartlett 914
post Jun 13 2015, 02:11 PM
QUOTE(SirAndy @ Jun 13 2015, 01:03 PM) *
I thought the cht circuit open would make the car run rich. If it is running rich then I wouldn't think spraying additional fuel would help.
I put a pressure gauge in place of the cold start injector. In my car, I never need it anyway so the gauge stays in place
914_teener
post Jun 15 2015, 11:14 AM
QUOTE(Bartlett 914 @ Jun 13 2015, 01:11 PM) *
Without the ECU seeing a ground from the CHT......the car will not run....period.
stugray
post Jun 15 2015, 11:51 AM
QUOTE(914_teener @ Jun 15 2015, 11:14 AM) *
If you just ground the CHT wire to the engine case it should start IF the temp sensor is the problem.
Shorting that wire to ground just looks like a head temp of greater than 300F.
So it should run rough but start because the ECU just thinks the engine is warmed up when it is not.
DavidSweden   Suddeny it wont run   Jun 13 2015, 06:59 AM
catsltd   I would pull a plug and make sure its dry and clea...   Jun 13 2015, 07:28 AM
Spoke   Spraying starting fluid in the throttle will let y...   Jun 13 2015, 07:58 AM
Elliot Cannon   Fuel pump running? Out of gas? :D   Jun 13 2015, 10:35 AM
DavidSweden   Fuel pump running? Out of gas? :D I squirted...   Jun 13 2015, 11:18 AM
larss   ...Whats the best way to check the fuel pressure....   Jun 15 2015, 12:32 PM
DavidSweden   ...Whats the best way to check the fuel pressure...   Jun 15 2015, 12:38 PM
larss   [quote name='larss' post='2199034' date='Jun 15 2...   Jun 15 2015, 12:46 PM
DavidSweden   Lars the pump is running I have just over 28 psi   Jun 15 2015, 12:50 PM
larss   Lars the pump is running I have just over 28 psi ...   Jun 15 2015, 12:52 PM
SirAndy   Stock D-Jet? If so, check the CHT, the wire may ha...   Jun 13 2015, 12:03 PM
Bartlett 914   Stock D-Jet? If so, check the CHT, the wire may h...   Jun 13 2015, 02:11 PM
BeatNavy   Stock D-Jet? If so, check the CHT, the wire may ...   Jun 13 2015, 02:57 PM
DavidSweden   [quote name='Bartlett 914' post='2198374' date='J...   Jun 14 2015, 11:57 AM
SirAndy   Stock D-Jet? If so, check the CHT, the wire may h...   Jun 14 2015, 12:16 PM
914_teener   Stock D-Jet? If so, check the CHT, the wire may ...   Jun 15 2015, 11:14 AM
stugray   [quote name='Bartlett 914' post='2198374' date='J...   Jun 15 2015, 11:51 AM
DavidSweden   :bump: Anyone out there who can help? Pretty ple...   Jun 15 2015, 10:21 AM
BeatNavy   Can you describe how you measured the CHT resistan...   Jun 15 2015, 10:39 AM
Philip W.   the last time mine did something like this it ende...   Jun 15 2015, 10:49 AM
Jeff Bowlsby   Does the MPS hold vacuum?   Jun 15 2015, 11:53 AM
DavidSweden   Does the MPS hold vacuum? I hope so Jeff it wa...   Jun 15 2015, 11:58 AM
914_teener   Does the MPS hold vacuum? I hope so Jeff it w...   Jun 15 2015, 12:43 PM
Spoke   You can check for a stuck cold start injector. Tha...   Jun 15 2015, 12:11 PM
DavidSweden   You can check for a stuck cold start injector. Th...   Jun 15 2015, 12:15 PM
Philip W.   You can check for a stuck cold start injector. T...   Jun 15 2015, 12:33 PM
cpavlenko   What's cht, just wondering. Trying to keep up ...   Jun 15 2015, 12:45 PM
larss   You wrote in the 1st post that it was misfiring, i...   Jun 15 2015, 12:51 PM
larss   For how long have you been driving the car without...   Jun 15 2015, 12:53 PM
- Lo-Fi Version Time is now: 11th July 2025 - 04:18 PM
