Friday, 8 August 2025 |
DavidSweden |
Member ![]() ![]() Group: Members Posts: 481 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia ![]() |
Went out for a short drive this morning. When I got back I parked up the car and shut of the engine. A few minutes later when I should start her up I had difficulty getting her going, the engine started but misfired badly. It then cut out and refuses to start. I have a Petronix but there is a spark. Any ideas on where to start?
Thanks |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Fuel pump running? Out of gas? (IMG:style_emoticons/default/biggrin.gif)
DavidSweden |
I squirted starter fluid into the throttle and it fired and ran very irregularly. then it stopped. The fuel tubing feels like there is fuel under pressure and the fuel pump is running. I can smell gas Whats the best way to check the fuel pressure, and do I have to pull the tank to get att the fuel filter? Any other ideas why it should suddenly die? This car would test the patience of a saint (IMG:style_emoticons/default/headbang.gif) |
larss |
Member ![]() ![]() Group: Members Posts: 431 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia ![]() |
DavidSweden |
...Whats the best way to check the fuel pressure... On the steel fuel line between the injectors on one side there is a T-tube with a small bolt at the end, just undo the bolt an hook up a pressure gauge on it and make the pump running. /Lars S Lars, tack för svaret men jag fattar inte riktigt vad du menar, kan du ta det på Svenska istället. Yes this is Swedish |
larss |
...Whats the best way to check the fuel pressure... On the steel fuel line between the injectors on one side there is a T-tube with a small bolt at the end, just undo the bolt an hook up a pressure gauge on it and make the pump running. /Lars S Lars, tack för svaret men jag fattar inte riktigt vad du menar, kan du ta det på Svenska istället. Yes this is Swedish No I refuse Swedish (IMG:style_emoticons/default/biggrin.gif) See no 86 in this picture, the small nipple in the middle of that tube, thats where you connect the pressure meter. It might be on either side of the engine. /Lars S (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-10787-1434393969.1.jpg) |
DavidSweden |
Lars the pump is running I have just over 28 psi |
Lo-Fi Version | Time is now: 8th August 2025 - 01:57 PM |
