> Suddeny it wont run, This car is getting the better of me
DavidSweden
post Jun 13 2015, 06:59 AM
Went out for a short drive this morning. When I got back I parked up the car and shut of the engine. A few minutes later when I should start her up I had difficulty getting her going, the engine started but misfired badly. It then cut out and refuses to start. I have a Petronix but there is a spark. Any ideas on where to start?
Thanks
larss
post Jun 15 2015, 12:53 PM
For how long have you been driving the car without problems, was this the first test run or...?
/lars S
DavidSweden   Suddeny it wont run   Jun 13 2015, 06:59 AM
catsltd   I would pull a plug and make sure its dry and clea...   Jun 13 2015, 07:28 AM
Spoke   Spraying starting fluid in the throttle will let y...   Jun 13 2015, 07:58 AM
Elliot Cannon   Fuel pump running? Out of gas? :D   Jun 13 2015, 10:35 AM
DavidSweden   Fuel pump running? Out of gas? :D I squirted...   Jun 13 2015, 11:18 AM
larss   ...Whats the best way to check the fuel pressure....   Jun 15 2015, 12:32 PM
DavidSweden   ...Whats the best way to check the fuel pressure...   Jun 15 2015, 12:38 PM
larss   [quote name='larss' post='2199034' date='Jun 15 2...   Jun 15 2015, 12:46 PM
DavidSweden   Lars the pump is running I have just over 28 psi   Jun 15 2015, 12:50 PM
larss   Lars the pump is running I have just over 28 psi ...   Jun 15 2015, 12:52 PM
SirAndy   Stock D-Jet? If so, check the CHT, the wire may ha...   Jun 13 2015, 12:03 PM
Bartlett 914   Stock D-Jet? If so, check the CHT, the wire may h...   Jun 13 2015, 02:11 PM
BeatNavy   Stock D-Jet? If so, check the CHT, the wire may ...   Jun 13 2015, 02:57 PM
DavidSweden   [quote name='Bartlett 914' post='2198374' date='J...   Jun 14 2015, 11:57 AM
SirAndy   Stock D-Jet? If so, check the CHT, the wire may h...   Jun 14 2015, 12:16 PM
914_teener   Stock D-Jet? If so, check the CHT, the wire may ...   Jun 15 2015, 11:14 AM
stugray   [quote name='Bartlett 914' post='2198374' date='J...   Jun 15 2015, 11:51 AM
DavidSweden   :bump: Anyone out there who can help? Pretty ple...   Jun 15 2015, 10:21 AM
BeatNavy   Can you describe how you measured the CHT resistan...   Jun 15 2015, 10:39 AM
Philip W.   the last time mine did something like this it ende...   Jun 15 2015, 10:49 AM
Jeff Bowlsby   Does the MPS hold vacuum?   Jun 15 2015, 11:53 AM
DavidSweden   Does the MPS hold vacuum? I hope so Jeff it wa...   Jun 15 2015, 11:58 AM
914_teener   Does the MPS hold vacuum? I hope so Jeff it w...   Jun 15 2015, 12:43 PM
Spoke   You can check for a stuck cold start injector. Tha...   Jun 15 2015, 12:11 PM
DavidSweden   You can check for a stuck cold start injector. Th...   Jun 15 2015, 12:15 PM
Philip W.   You can check for a stuck cold start injector. T...   Jun 15 2015, 12:33 PM
cpavlenko   What's cht, just wondering. Trying to keep up ...   Jun 15 2015, 12:45 PM
larss   You wrote in the 1st post that it was misfiring, i...   Jun 15 2015, 12:51 PM
larss   For how long have you been driving the car without...   Jun 15 2015, 12:53 PM
- Lo-Fi Version Time is now: 11th July 2025 - 04:21 PM
