> Found after motor back in
last337
post Jun 14 2015, 02:20 PM
Of course as soon as I get the motor back in I look in toolbox and see a few bolts and nuts sitting there, staring at me. I have been staring at all visible areas and I am at a loss. Thought maybe someone might have an idea based on what I have done:
Pulled motor
Removed all tin, impeller housing pieces, alternator mount
Impeller
Oil cooler (replaced seals)
Transmission separated
flywheel/clutch removed
I did all the above over a year ago when I started fixing hellhole and longs and took apart more than I needed but used chance to clean everything thoroughly
So I have what looks to be the following left:
three M8 x 40 bolts
three A8 spring washers
two M8 x 20 bolts and matching M8 nuts
I was a bit worried they were for impeller (only place I remember 3 bolts) but I remember putting those on. I dont recall putting the M8x20's back into the oil cooler brackets so that might account for those two but leaves me with a really odd number of things left. I also dont remember using anything on shroud/tin but the 4 nuts and spring washers that hold it to the front of the motor.
I am really kickin myself over this and I know I could easily take it all apart and still not find any spots for these. I have been going through exploded diagrams and just lost. Its possible these were from somewhere else in engine bay or maybe even just floating in car when I got it but it was too long ago even as organized as I tried to be with it.
Any help or suggestions are appreciated
crash914
post Jun 16 2015, 02:56 AM
its a mystery to me
bolts to hold on the fan? uses 3 m8's
last337   Found after motor back in   Jun 14 2015, 02:20 PM
arkitect   Maybe you replaced them with new? and they are ext...   Jun 14 2015, 02:44 PM
last337   I wish that was the case but I only bought new mot...   Jun 14 2015, 03:17 PM
914Mike   I wish that was the case but I only bought new mo...   Jun 14 2015, 04:44 PM
last337   I wish that was the case but I only bought new m...   Jun 14 2015, 05:09 PM
wndsnd   Not rusty. Sure they came from your 914?   Jun 14 2015, 05:33 PM
rmital   Not rusty. Sure they came from your 914? :agre...   Jun 15 2015, 08:16 AM
Dave_Darling   Engine tin is almost all M6. There is one M8 fast...   Jun 14 2015, 07:24 PM
last337   Thanks for the replies. I still cant find anyone ...   Jun 15 2015, 07:50 AM
mbseto   I know if I get miffed at a car buddy, I'll go...   Jun 15 2015, 08:12 AM
nathansnathan   The only place the pet list 8 x 40 is the upper an...   Jun 15 2015, 09:00 AM
last337   The only place the pet list 8 x 40 is the upper a...   Jun 15 2015, 09:49 AM
SLITS   #15 holds the blower housing halves together (peri...   Jun 15 2015, 11:01 AM
nathansnathan   http://www.porsche.com/all/media/pdf/origi...914_K...   Jun 15 2015, 05:48 PM
last337   I measured them and sure enough they are M8x30s. ...   Jun 15 2015, 07:31 PM
falcor75   I've got a similar but opposite issue...I have...   Jun 15 2015, 11:12 PM
larss   I've got a similar but opposite issue...I hav...   Jun 16 2015, 11:44 AM
crash914   bolts to hold on the fan? uses 3 m8's   Jun 16 2015, 02:56 AM
falcor75   The fan bolts are much longer, something like 45 o...   Jun 16 2015, 05:20 AM
nathansnathan   Yeah, the bolts to hold the fan to the fan hub are...   Jun 16 2015, 07:25 AM
- Lo-Fi Version Time is now: 1st August 2025 - 02:54 AM
