| DavidSweden |
Jun 16 2015, 02:54 PM
Member ![]() ![]() Group: Members Posts: 481 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Can anyone tell how to test if the cold start valve is stuck open?
Thanks |
| Ian Stott |
Jun 17 2015, 04:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Any chance you could post a picture of that, I need to do that.
Ian Stott Moncton Canada |
| r_towle |
Jun 17 2015, 07:51 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Any chance you could post a picture of that, I need to do that. Ian Stott Moncton Canada No pics but it's simple The cold start valve is shaped like a t splitter Fuel comes in one side and goes out the other. So. Pull off both fuel lines and put a piece of tubing inside both ends to connect them together....now no fuel will go through the cold start injector |
DavidSweden Cold start vale Jun 16 2015, 02:54 PM
pilothyer
Can anyone tell how to test if the cold start val... Jun 16 2015, 06:44 PM
worn
Can anyone tell how to test if the cold start val... Jun 17 2015, 09:05 AM
r_towle get a piece of brake tubing the correct diameter a... Jun 17 2015, 09:41 AM
DavidSweden
Any chance you could post a picture of that, I n... Jun 18 2015, 10:20 AM
pilothyer The L-Jet has two ports, Maybe he thought you had ... Jun 18 2015, 01:25 PM
r_towle ok, so its one port.
remove the t-connector in the... Jun 18 2015, 01:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 08:09 AM |
