> Fitting Pedrini wheels to 1974 914 2.0
Autokennel
post Jun 17 2015, 03:29 PM
So I just found this nice set of original date stamped 1971/72 Pedrini wheels that I thought would look much better on my '74 2.0 than the Riviera's (stay tuned...will be for sale shortly). I plan on running the stock 165/80 15 tires as well.
The rears bolted up fine (of course, I had to go out and buy a set of 40mm length thread bolts as the Riviera's only used 25mm length). Then, when we went to mount the fronts, we realized that the front brake disc rotors had a hub centric ring and the back of the Pedrini's had a countersunk shape (see pics below).
Any suggestions how to make these work?
(BTW, the Rears fit just fine)
Thanks
Paul
Dave_Darling
post Jun 17 2015, 10:01 PM
914 Idiot
I know of three ways to make the .00 part number wheels work on a later car:
- Mill a recess in the back of the wheel for the centering ring on the late hub
- Mill off the centering ring from the late hub
- Change the struts and hubs (rotors) over to the early style with the pinch-bolt rather than the wedge pin ball joint
I'm not a fan of any of those, frankly. I suggest swapping the wheels out for ones that actually fit.
--DD
- Lo-Fi Version Time is now: 9th July 2025 - 03:20 PM
