> Valve adjustment, How the Fuchs with the HS in the way
DavidSweden
post Jun 19 2015, 08:02 AM
Some of you may have read my earlier thread where I described the engine would not restart..
Well I checked out the wiring harnesses at the brain end and everything checked out.
I have ordered a new CHT and have replaced the rotor and cap this is just to see if it gets it going as I have not found the problem
Anyway I decided to check the valve clearance after reading the appropriate literature I hoisted the car only to be once again totally pissed by the design of this car.
Question
Is it possible to remove the valve covers and adjust the valves with the heat exchangers in place?
I am starting to regret that I bought this car (IMG:style_emoticons/default/headbang.gif) moral support and possibly some therapy will be require (IMG:style_emoticons/default/blink.gif)
somd914
post Jun 19 2015, 08:55 AM
And make sure innocent ears are within hearing distance...
For the most part I find working on a 914 easy. However, valve adjustments with heat exchangers on and with the car on stands is an absolute PITA. Sometimes I think it would be easier, or at least less frustrating, to drop the engine.
Also, I have found it easier to pop the bails upward for removal, and have found it easier to reinstall the covers with the bails downward. Removing or at least loosening the heat plumbing on the passenger side in front of the exchanger has also gained me some much needed working room for #4.
DavidSweden   Valve adjustment   Jun 19 2015, 08:02 AM
dabird   Some of you may have read my earlier thread where...   Jun 19 2015, 08:22 AM
Bleyseng   With the car on a lift it's pretty easy if you...   Jun 19 2015, 08:42 AM
type47   Is it possible to remove the valve covers and adj...   Jun 19 2015, 08:49 AM
somd914   And make sure innocent ears are within hearing dis...   Jun 19 2015, 08:55 AM
SLITS   To pop the valve covers off, I thread a shop rag t...   Jun 19 2015, 09:11 AM
Kansas 914   It isn't the easiest thing to do, but it is...   Jun 19 2015, 09:30 AM
SLITS   It isn't the easiest thing to do, but it i...   Jun 19 2015, 11:01 AM
Old Yella   Hi I did mine with the late exhaust, now that is a...   Jun 19 2015, 09:26 AM
brant   It's really not that bad.   Jun 19 2015, 09:35 AM
scott_in_nh   It's really not that bad. :agree: I use ...   Jun 19 2015, 11:07 AM
r_towle   It's really not that bad. :agree: I use...   Jun 19 2015, 09:13 PM
Geezer914   Things could be worse. The more you do it the eas...   Jun 19 2015, 10:28 AM
Dave_Darling   On 914s with the 70-74 style exhausts, access is a...   Jun 19 2015, 10:33 AM
dlestep   in my driveway, which is slightly slanted, nose A...   Jun 19 2015, 09:49 PM
rhodyguy   Ron's way with the cloth on the bale. It doesn...   Jun 19 2015, 11:08 PM
rjames   I'd rather de with the exchangers being in the...   Jun 20 2015, 01:01 AM
Spoke   Don't let your car get you down. These are 40+...   Jun 20 2015, 05:35 AM
TX914   The bent Tommy bar in the stock toolkit (for use w...   Jun 20 2015, 06:09 AM
Java2570   The first time I tried valve adjustment, it was fr...   Jun 20 2015, 08:46 AM
- Lo-Fi Version Time is now: 8th December 2025 - 03:04 AM
