| Ian Stott |
Jun 21 2015, 05:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Does the cold start valve just matter when engine is cold? When engine is warmed up could you bypass the cold start valve with no issues?
Ian Stott Moncton Canada |
| Spoke |
Jun 21 2015, 06:31 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,398 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
The cold start valve operates only below freezing (0C). Once the case temperature is above freezing, the cold start valve is not active.
Ian Stott Cold start valve Jun 21 2015, 05:15 AM
Tom_T
The cold start valve operates only below freezing... Jun 21 2015, 04:35 PM
SLITS I have more than once disabled the cold start valv... Jun 21 2015, 06:52 AM
VegasRacer
On my /6 they are disabled also.
Never had a pro... Jun 21 2015, 07:03 AM
r_towle The ECu is most likely not the issue, so don't... Jun 21 2015, 05:16 PM
Ian Stott Can you just unplug the electrical connection and ... Jun 22 2015, 02:42 AM
r_towle Just unplug the electrics and the fuel line...simp... Jun 22 2015, 05:52 AM
mepstein Cold start valve isn't working right
Replace t... Jun 22 2015, 09:40 AM
Ian Stott Cold start valve electrical unhooked, fuel line di... Jun 23 2015, 05:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd June 2026 - 11:17 PM |
