76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,736 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Judging from the WCR Wine Tasting Tour, I thought some of you might be up for a "local" Wine Tasting Tour w/ the wives. This is an excellent opportunity to add some "brownie points" with the wife which translates, "more 914 time for you". We can do lunch here (on me) then move on to the wineries. It's something that we would need to do before (or after) it gets too hot. If 7-8 of you commit I'll put it together. (IMG:style_emoticons/default/beerchug.gif)
forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
Susan and I will attend if I can get my new motor sorted out and road-tested prior to the 20th. As of yesterday, the motor is in and running but has an untested side shifter tranny to be hooked up today and a weird ignition wire issue with no juice to the fuel pump???.
(IMG:style_emoticons/default/beerchug.gif) |
76-914 |
Susan and I will attend if I can get my new motor sorted out and road-tested prior to the 20th. As of yesterday, the motor is in and running but has an untested side shifter tranny to be hooked up today and a weird ignition wire issue with no juice to the fuel pump???. (IMG:style_emoticons/default/beerchug.gif) How'd did you get it started with a non-working fuel pump? (IMG:style_emoticons/default/confused24.gif) You have 3 weeks; I'm sure you'll have things sorted out by that point. (IMG:style_emoticons/default/beerchug.gif) |
forrestkhaag |
Susan and I will attend if I can get my new motor sorted out and road-tested prior to the 20th. As of yesterday, the motor is in and running but has an untested side shifter tranny to be hooked up today and a weird ignition wire issue with no juice to the fuel pump???. (IMG:style_emoticons/default/beerchug.gif) How'd did you get it started with a non-working fuel pump? (IMG:style_emoticons/default/confused24.gif) You have 3 weeks; I'm sure you'll have things sorted out by that point. (IMG:style_emoticons/default/beerchug.gif) With a winch and a AAA Premier card..... When I returned home, it fired right up / I took it for a drive to confirm usefulnesss for the Temecula run (now past) and it died for good on PCH / no sound from the almost brand new pump / so today, I will chase it down to either a wiring issue or a pump issue........ Sorry we missed the event. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 8th July 2025 - 08:10 PM |
