| jim_hoyland |
Jun 22 2015, 07:46 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,079 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Thanks to Socalandy; I have a replacement VIN sticker for the driver side door jamb. The original sticker got mangled and needs to be replaced; it's stuck on the metal pretty good. What's the best way to loosen the adhesive so the sticker can be peeled back and removed ?
| jim_hoyland |
Jun 23 2015, 06:10 AM
Update: Used the heat gun with a popcycle stick that was filed to look like a chisel. Took all of 5 minutes to remove the sticker. Then I used Terpentine to remove the remaining adhesive. Worked out great (IMG:style_emoticons/default/smile.gif)
And under the old VIN was the original color of the car...... |
jim_hoyland Removing a VIN sticker Jun 22 2015, 07:46 PM
Mike Bellis Hair dryer or heat gun. Don't get it too hot... Jun 22 2015, 07:54 PM
jim_hoyland
Hair dryer or heat gun. Don't get it too hot... Jun 22 2015, 07:56 PM
Mike Bellis When the paint bubbles, that's too hot.
You w... Jun 22 2015, 08:17 PM
toolguy Use a Popsicle stick or better yet a doctors tongu... Jun 22 2015, 08:28 PM
jim_hoyland Thanks. Jun 22 2015, 08:37 PM
RobW I've found goo be gone to work well in certain... Jun 22 2015, 10:09 PM
MJHanna Don't laugh but they make plastic razer blades... Jun 23 2015, 05:56 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th June 2026 - 09:10 AM |
