| cpavlenko |
Jun 23 2015, 12:31 PM
Member ![]() ![]() Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
| cpavlenko |
Jun 23 2015, 02:56 PM
well, it's 105 degrees out side, and I took the teener out for a 40 mile cruise. when I got back home and checked my oil temp dip stick, it was at 250 degrees. this is to hot, seemed to run cooler without the flaps? so what I'm going to do is remove them and take the same cruise tomorrow and see if there's a difference. also I'm going to put the right clamps on. I have some extras. Air cooled only did that, and I'm going to call bout that. the temp is going to be the same here tomorrow.
| screenguy914 |
Jun 23 2015, 04:28 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
well, it's 105 degrees out side, and I took the teener out for a 40 mile cruise. when I got back home and checked my oil temp dip stick, it was at 250 degrees. this is to hot, seemed to run cooler without the flaps? so what I'm going to do is remove them and take the same cruise tomorrow and see if there's a difference. also I'm going to put the right clamps on. I have some extras. Air cooled only did that, and I'm going to call bout that. the temp is going to be the same here tomorrow. Some would like to know the purpose of the plastic rail(s) under the engine. Me too. As for overheating, I would say one big factor is the 105ºF ambient temps. Not sure about the equipment on your engine, but an external oil cooler might be in order if that's the typical operating condition where you live. Sherwood |
| cpavlenko |
Jun 23 2015, 08:57 PM
well, it's 105 degrees out side, and I took the teener out for a 40 mile cruise. when I got back home and checked my oil temp dip stick, it was at 250 degrees. this is to hot, seemed to run cooler without the flaps? so what I'm going to do is remove them and take the same cruise tomorrow and see if there's a difference. also I'm going to put the right clamps on. I have some extras. Air cooled only did that, and I'm going to call bout that. the temp is going to be the same here tomorrow. Some would like to know the purpose of the plastic rail(s) under the engine. Me too. As for overheating, I would say one big factor is the 105ºF ambient temps. Not sure about the equipment on your engine, but an external oil cooler might be in order if that's the typical operating condition where you live. Sherwood yea, I'm thinking the same thing. But during the winter it gets cold in northern AZ. also I was wrong on outside temperature, it was only 95 degrees. |
cpavlenko Installed Jun 23 2015, 12:31 PM
JStroud Looks good, next upgrade I would do is replace the... Jun 23 2015, 12:43 PM
cpavlenko Rubber fuel line hose through the whole car was co... Jun 23 2015, 01:02 PM
Cevan I'd suggest using FI clamps instead of the one... Jun 23 2015, 01:56 PM
Chris914n6
I'd suggest using FI clamps instead of the on... Jun 23 2015, 03:12 PM
914Mels Stupid question, but what purpose do the deflector... Jun 23 2015, 02:05 PM
cpavlenko
Stupid question, but what purpose do the deflecto... Jun 23 2015, 09:27 PM
cpavlenko stock 1971 1.7. no frills. Jun 23 2015, 04:42 PM
budk The plastic flaps or deflectors are to create a lo... Jun 23 2015, 06:50 PM
cpavlenko
The plastic flaps or deflectors are to create a l... Jun 23 2015, 08:45 PM
Garold Shaffer
The plastic flaps or deflectors are to create a ... Jun 23 2015, 08:49 PM
cpavlenko
[quote name='cpavlenko' post='2201833' date='Jun ... Jun 24 2015, 01:59 PM
rudedude Where did you find a set of new looking deflectors... Jun 23 2015, 07:28 PM
cpavlenko
Where did you find a set of new looking deflector... Jun 23 2015, 08:51 PM
Eric_Shea Don't bother taking them off. That's not y... Jun 24 2015, 08:09 AM
cpavlenko
Don't bother taking them off. That's not ... Jun 24 2015, 08:58 AM
rhodyguy Just release the bellows control wire at the rod a... Jun 24 2015, 08:21 AM
SLITS Did you clean your on engine oil cooler?
While yo... Jun 24 2015, 08:49 AM
cpavlenko
While y... Jun 24 2015, 09:00 AM
rhodyguy Try ron's idea first. Jun 24 2015, 08:57 AM
rhodyguy Put a catch basin on the floor under the cooler. I... Jun 24 2015, 09:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 05:00 PM |
