> Installed, floor pan deflectors
cpavlenko
post Jun 23 2015, 12:31 PM
Wasn't to bad, would've been much easier with a 4 post lift. I only had drive up ramps and jack stands. All went well. Attached Image Attached Image
SLITS
post Jun 24 2015, 08:49 AM
"This Utah shit is HARSH!"
Did you clean your on engine oil cooler?
While you really can't get it from the top, I use brake cleaner and spray up from the bottom. I then use compressed air to blow anything out of the fins, realizing that the foreign material is blown back on the cylinders.
Might be worth a try.
cpavlenko
post Jun 24 2015, 09:00 AM
QUOTE(SLITS @ Jun 24 2015, 07:49 AM) *
I'll give that a try.
cpavlenko   Installed   Jun 23 2015, 12:31 PM
JStroud   Looks good, next upgrade I would do is replace the...   Jun 23 2015, 12:43 PM
cpavlenko   Rubber fuel line hose through the whole car was co...   Jun 23 2015, 01:02 PM
Cevan   I'd suggest using FI clamps instead of the one...   Jun 23 2015, 01:56 PM
Chris914n6   I'd suggest using FI clamps instead of the on...   Jun 23 2015, 03:12 PM
914Mels   Stupid question, but what purpose do the deflector...   Jun 23 2015, 02:05 PM
cpavlenko   Stupid question, but what purpose do the deflecto...   Jun 23 2015, 09:27 PM
cpavlenko   well, it's 105 degrees out side, and I took th...   Jun 23 2015, 02:56 PM
screenguy914   well, it's 105 degrees out side, and I took t...   Jun 23 2015, 04:28 PM
cpavlenko   well, it's 105 degrees out side, and I took ...   Jun 23 2015, 08:57 PM
cpavlenko   stock 1971 1.7. no frills.   Jun 23 2015, 04:42 PM
budk   The plastic flaps or deflectors are to create a lo...   Jun 23 2015, 06:50 PM
cpavlenko   The plastic flaps or deflectors are to create a l...   Jun 23 2015, 08:45 PM
Garold Shaffer   The plastic flaps or deflectors are to create a ...   Jun 23 2015, 08:49 PM
cpavlenko   [quote name='cpavlenko' post='2201833' date='Jun ...   Jun 24 2015, 01:59 PM
rudedude   Where did you find a set of new looking deflectors...   Jun 23 2015, 07:28 PM
cpavlenko   Where did you find a set of new looking deflector...   Jun 23 2015, 08:51 PM
Eric_Shea   Don't bother taking them off. That's not y...   Jun 24 2015, 08:09 AM
cpavlenko   Don't bother taking them off. That's not ...   Jun 24 2015, 08:58 AM
rhodyguy   Just release the bellows control wire at the rod a...   Jun 24 2015, 08:21 AM
SLITS   Did you clean your on engine oil cooler? While yo...   Jun 24 2015, 08:49 AM
cpavlenko   Did you clean your on engine oil cooler? While y...   Jun 24 2015, 09:00 AM
rhodyguy   Try ron's idea first.   Jun 24 2015, 08:57 AM
rhodyguy   Put a catch basin on the floor under the cooler. I...   Jun 24 2015, 09:08 AM
- Lo-Fi Version Time is now: 12th March 2026 - 05:00 PM
