> Vintage Brake - 914-6/GT Alloy Rear Calipers, Now Shipping!
Eric_Shea
post Dec 25 2012, 08:19 PM
PMB Performance
Finally!!! The answer for those wanting the legendary 914-6/GT rear calipers on their car. New, ultra lightweight alloy rear calipers from "Vintage Brakes" are shipping now.
Experience the legendary stopping power the factory race team had when they won LeMans back in 1970. These 914-6/GT calipers give you a 38mm piston which is 15% larger than a stock 914 rear caliper piston. They also use an FMSI standard D31 pad which is 13% larger than stock 914... all in a package that is 5lbs. lighter per side! That's 10lbs. of unsprung weight taken off the back of your 914 race car (or 911 for that matter... drop the handbrake assembly and loose even more weight).
So... what does this mean for you? Well, the larger piston and pad size mirror that of it's Brother, the 911. Nearly every 911 had a 38mm piston and D31 pad in the rear from the legendary 911RS to the last 911SC in 1983. In fact, this is the same arrangement the factory put in a 914-6. Have you checked the prices on used 914-6 and 914-6/GT calipers (if you can find these hens teeth)? This means you can now bolt on just about any 911 front caliper you'd like and maintain a factory brake bias. Want to run a 914-6 stock setup? Run these (stock 6 versions are without spacers and $100 less) and a pair of 911 M-Calipers up front. Move up to legendary GT status? Add a pair of S-Calipers (cast off the same 908 casting the LeMans cars ran) and run these in the back. So now you can finally bolt on some brakes to your 914 and have it "factory perfect."
Handbrake? You bet, you can have big brakes and a stock handbrake assembly. Use stock handbrake cables and have a system designed specifically for your 914... a 914 handbrake system!
Our DuroAno finish on the calipers and the specifically designed pistons make these harder than steel! Our upgraded M8 (over stock M7) fasteners help keep the flex down to .002" (human hair) over their steel counterparts.
While you probably won't need vented rotors in the rear of your 914, these GT versions have the spacers added so they fit over wider, cooler running vented rotors*.
Finally, the perfect solution for all of these 914's that have a nice bump in horsepower... a nice bump in stopping power.
*Used with stock 911 rear rotors, these will need about 4.5mm worth of spacers (washers) under the caliper mounting ears or a spacer "under" the rotor. 914-6/GT rear rotors are still available from the factory for those who want to get the real deal from Germany (call for a quote).
(IMG:http://www.914world.com/bbs2/uploads_offsite/4.bp.blogspot.com-1110-1356488929.1.jpg)
PMB Performance
162 W. 9240 S.
Sandy, UT 84070
855-STOP-101
855-786-7101
sales@pmbperformance.com
www.pmbperformance.com
Love us on Facebook:
https://www.facebook.com/PMBPerfomance
http://www.pmbperformance.com/catalog/item...676/9663436.htm]
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pmbperformance.com-1110-1356488397.1.JPG)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pmbperformance.com-1110-1356488398.2.JPG)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pmbperformance.com-1110-1356488398.3.JPG)
Glovebox
post Jun 24 2015, 09:02 AM
Eric! Please help !! Mine are leaking like crazy !!
Regards Mark.
Eric_Shea   Vintage Brake - 914-6/GT Alloy Rear Calipers   Dec 25 2012, 08:19 PM
ConeDodger   Tease! :angry: Want. Can't yet have!   Dec 25 2012, 09:09 PM
mepstein   Nice! :trophy:   Dec 26 2012, 06:16 AM
danimal16   I bought a pair of these for my project. Simply a...   Aug 26 2013, 11:11 AM
Kaeferfreund   Hi! Could anybody tell me/us some of his expe...   Feb 6 2015, 11:03 AM
raynekat   Unfortunately "sold out", but I still ho...   Feb 7 2015, 05:51 AM
mepstein   Mickey said Eric has these in stock so maybe the w...   Feb 7 2015, 08:00 AM
Glovebox   Eric! Please help !! Mine are leaking ...   Jun 24 2015, 09:02 AM
rdauenhauer   What ever happened with these? I had a wad of cas...   Jan 23 2018, 06:24 PM
raynekat   PMB sold them all out, what they had. They have no...   Jan 24 2018, 06:44 PM
mepstein   PMB sold them all out, what they had. They have n...   Jan 24 2018, 08:53 PM
rdauenhauer   Ok Ill bite ... Who told you? Since this is Erc...   Jan 24 2018, 06:54 PM
raynekat   Ok Ill bite ... Who told you? Since this is Erc...   Jan 27 2018, 12:15 AM
Mueller   Is that Vintage Brakes company still around? A q...   Jan 29 2018, 10:19 AM
ConeDodger   I bought the last set and no they aren’t for sal...   Feb 1 2018, 07:15 PM
lonewolfe   I bought the last set and no they aren’t for sa...   Feb 4 2018, 02:55 PM
mepstein   I bought the last set and no they aren’t for s...   Feb 4 2018, 03:46 PM
lonewolfe   [quote name='lonewolfe' post='2575042' date='Feb ...   Feb 4 2018, 09:41 PM
rdauenhauer   :(   Feb 2 2018, 08:26 PM
raynekat   The big difference is weight of course. The genuin...   Feb 5 2018, 11:14 PM
ConeDodger   The big difference is weight of course. The genui...   Feb 10 2018, 12:44 PM
rdauenhauer   But the question remains. If they were so Fab, at...   Feb 5 2018, 11:58 PM
raynekat   But the question remains. If they were so Fab, a...   Feb 6 2018, 07:13 PM
ConeDodger   But the question remains. If they were so Fab, ...   Feb 10 2018, 12:41 PM
mepstein   [quote name='raynekat' post='2575864' date='Feb 6...   Feb 10 2018, 01:01 PM
- Lo-Fi Version Time is now: 9th June 2026 - 06:51 PM
