> Back to square one
JoeSharpOld
post Sep 10 2004, 07:05 PM
Does it seem cold to you
This started about 6 months ago as what I thought was as intermiten open in a loom. Its /L. car and I've replaced the Loom (Thank you Mr. Blowsby) all lines and hoses, intake manifold gaskets and boots, adjusted the valves, new injectors. What it is doing is fouling plugs at 3/2.
(IMG:style_emoticons/default/headbang.gif) Whats up wit dat (IMG:style_emoticons/default/unsure.gif)
Joe
Joe Sharp Old   Back to square one   Sep 10 2004, 07:05 PM
Aaron Cox   bummer joe! i hope it all sorts out :unsure:   Sep 10 2004, 07:28 PM
Joe Sharp Old   I know that it will. What I'm thinking now is ...   Sep 10 2004, 07:42 PM
Joe Ricard   Trigger points.. Must set gap. Oops never mind ...   Sep 10 2004, 07:56 PM
redshift   Try to keep your wires the same length though, the...   Sep 10 2004, 08:35 PM
Joe Sharp Old   Joe: After the GAF I'll check the pulg wires, ...   Sep 10 2004, 09:49 PM
SLITS   rotor, cap, high tension cables, points first de...   Sep 10 2004, 10:17 PM
Aaron Cox   sometimes your just like... http://www.flyingcirku...   Sep 10 2004, 10:30 PM
Joe Sharp Old   SLITS: I'm at your third. Fourth is not an opt...   Sep 10 2004, 10:53 PM
phantom914   Umm... how would the CHT cause anything different ...   Sep 10 2004, 11:05 PM
nebreitling
- Lo-Fi Version Time is now: 2nd August 2025 - 02:38 AM
