temp sensor |
temp sensor |
last337 |
Jun 29 2015, 06:58 AM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
Does anyone know where the temp sensor wire connects to? I cant seem to trace it down in the wiring chart. The hard coating came off but I still have the underlying wire with the spade connection at the end just cant recall where it connects.
BeatNavy |
Jun 29 2015, 07:23 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I can only speak to D-Jet. I assume you're talking about TS2, Cylinder Head Temp (CHT) sensor. The wire comes out of the actual sensor which should be coming out of a hole in the tin near spark plug #3. It then connects to a white wire (I believe) coming out of the Fuel Injection wiring harness which is pin 23 on the ECU connector. If the FI harness is connected properly it should be pretty clear which lead is closest to that sensor. Is that what you're looking for?
TS1, the air temperature sensor, has a two lead connector that also connects into the FI wiring harness. Might help if you tell more about your car (year, engine, stock FI, etc.). |
Lo-Fi Version | Time is now: 1st June 2024 - 01:43 PM |
