Stuck Fuel pressure regulator? |
pete000 |
Jun 30 2015, 04:20 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
74 1.8 L-Jet
Has any one ever had a fuel pressure regulator get stuck from sitting dry? My car has been on jack stands for 4 years. and I finally got all the fuel lines back in. No fuel was going to the fuel rails. I tested the pump and its pumping just fine but no fuel seems to get past the pressure regulator. I took it apart and soaked it in gas and bench tested it with the pump and it seems to be flowing good now. I also checked the cold start valve, fuel rails, and they are not blocked. Have to put it all back in and see. Seems like it just got stuck and would not allow fuel flow. Possible? |
jcd914 |
Jun 30 2015, 04:46 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Fuel Pressure Regulator is at the end of the fuel loop and would not stop fuel from getting to the injectors.
Fuel goes from tank to pump to injectors to press reg to tank. If it were stuck close fuel pressure would max out at what ever the pump could generate (on my explorer that about 100psi). If it were stuck open the fuel pressure would be very low. Jim |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:04 PM |
