> how 2 remove CV joint from stub axle?, is there a trick/tool?
opera guy
post Sep 9 2004, 03:25 PM
i need to take out my rear hub to drill it for 5 lug. but i cant seem to remove the cv joint from the stub axle. all 4 screws are off, is there a trick or a tool that im not aware of?
so far, i've been using a screw driver to mess around in there, but to no avail.
help (IMG:style_emoticons/default/type.gif)
opera guy
post Sep 10 2004, 11:48 PM
finally figured out how to take the driver side axle off.
1. point the tranny end (that has been removed) as close to the ground strap as possible.
2. jack under the trailing arm. just let the jack make contact with the trailing arm.
3. remove the nut to the top of the shock/spring assembly (under the trunk)
4. lower the jack/trailing arm. that should give you more room to wrestle off the axle.
5. after you're done with whatever it is you need to do with the axle.. re assemble in reverse order
glad i discovered this.. maybe everyone already knew it.. but i feel like i just reinvented the wheel (IMG:style_emoticons/default/biggrin.gif) pat, pat, pat (on my own back)
- Lo-Fi Version Time is now: 1st August 2025 - 05:53 PM
