> Body flex causing top fitment and window issues, On lift I get 25 1/8" and on the ground it changes to 25"?
Steve
post Jul 1 2015, 09:10 AM
What is the consensus on flex regarding the roll bar to windshield flange measurement?
Item "F" on the body dimensions page.
http://www.914world.com/specs/bodydims.php
My car was fine until I had a shop weld in the Engman long kit. The car is much stiffer, but the windows and top no longer fits right when the car is on the ground.
On the lift I get 25 1/8".
Off the lift I get exactly 25"
How much should the car flex when on my scissor lift versus on the ground?
The scissor lift is using the four jack pods to raise the car.
Should the car be like 25 1/4" on the lift and 25 1/8" on the ground?
Is 1/8" flex normal? What is everyone else seeing?
I will post some pictures tonight.
Luke M
post Jul 2 2015, 07:57 AM
Looking at the top of the door gap pics it seams to me that on the ground it gets tighter. With that said I agree with Rick you need to start looking at your jack points for rust. You really can't tell just by looks but need to start poking around. If you find some soft/rust areas that needs to be addressed. Like anything fix one thing and something else will pop up.
On my 6 I have the same issue with the door gaps and jack points.
The pass side looked ok in some spots and in others it had some small holes. The more I dug the more rust damage I found. At the end I had to replace the hole area with new metal from RD parts # PP351 & PP331.
- Lo-Fi Version Time is now: 7th July 2025 - 01:43 AM
