| JDW914 |
Jul 2 2015, 09:37 PM
Newbie ![]() Group: Members Posts: 25 Joined: 27-April 11 From: Toledo, Ohio Member No.: 12,990 Region Association: Upper MidWest |
Hi all! I recently took my first long road trip in my 914 (700 mi round trip out to Peoria, IL to finally pick up a replacement windshield) and while the car performed beautifully, I had my first encounter with what I've learned is the "infamous hot-start issue." Happily I was caravanning and, when unable to find a clear reason as to the car's failing to start after a pit stop for lunch, we tried jumping it, assuming the battery had gone bad, which resulted in enough current to pop the solenoid and start it up. This was necessary a few times during the trip. While it has never caused me trouble before (I've been driving the car pretty regularly for 2 years since its restoration has been "finished") I'd prefer to remove the issue so that it doesn't come back to bite me, especially now that the car has proven itself as such a good road-tripper.
Now in my research since encountering the issue, I've found much documentation of the issue and its solutions, in particular a Ford starter solenoid or a Bosch hot start relay kit. I'd like to go about it with the replacement starter solenoid as this seems a simple and straight-forward enough change-out, however, I've not been able to determine what solenoid it is in particular that will fit into an old VW starter motor. Is there a particular part number or set of models/years that use it, or does Ford have enough standardisation that any old solenoid will work? Thanks for any enlightenment you can provide! |
| rick 918-S |
Jul 4 2015, 07:25 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I chased that rabbit down the hole. Here's what I ended up doing. BTW: Thanks to Ed Morrow the best long distance trouble shooter ever! (IMG:style_emoticons/default/pray.gif)
Finished up Sandy's car last year in time to drive to Moab for the RRC. Starter failed on the way home. It was fall so we put the car away until spring. Spring rolls around and I put a starter in from Orielly's. and headed for the Route 66 event in Palm Springs. Starter failed as I neared Vegas or... so I thought. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/dry.gif) Stopped in Vegas and picked up a warrantee starter and changed it. Worked for the weekend. Failed in PS. Left the car there and flew home. Came back a month later and picked up the car and it started. Got the WCR and it quit again. worked off and on all weekend and for the drive home. Thought I just got a bad starter again. Picked up a Bosch re-man and swapped out the Orielly's unit. Worked but barely. Added a hot start solenoid, No Joy. Called Ed, he say's take a jumper cable and connect it from your negative post to the starter. WHAM!!! it starts like new! Cables were factory and looked clean and nice. Cali car with clean grounds, New braided ground strap. I replaced the negative cable to the body and the starter still didn't work. I then replaced the positive cable and WHAM! perfect! So my advise, Before changing anything us the "ED" test method! Then change the cables first, not last! |
JDW914 Which Sterter Solenoid? Jul 2 2015, 09:37 PM
stugray Are you talking about replacing the solenoid on th... Jul 2 2015, 11:09 PM
markb This is what I had on my 72 for years & never ... Jul 2 2015, 11:10 PM
john77 I had the same problem 12 months ago. I bought a h... Jul 3 2015, 01:42 AM
worn
I had the same problem 12 months ago. I bought a ... Jul 3 2015, 09:33 AM
Mark Henry The Ford solenoid is the on the fender type they u... Jul 3 2015, 07:59 AM
type47 There are lots of relays out there that can be use... Jul 3 2015, 09:50 AM
Mark Henry
There are lots of relays out there that can be us... Jul 3 2015, 10:11 AM
Tom_T You may have one or more of a few things going on ... Jul 3 2015, 10:28 AM
Mark Henry
You may have one or more of a few things going on... Jul 3 2015, 12:03 PM
Tom_T
#1 To me vapour lock and hot start are two diffe... Jul 3 2015, 03:21 PM
SLITS I use the "Ford Starter Solenoid Relay" ... Jul 3 2015, 10:38 AM
jeffdon I run a ford solenoid mounted on the starter. In... Jul 3 2015, 01:16 PM
JDW914 To be clear, my car's problem is that at high ... Jul 3 2015, 07:13 PM
Kansas 914
I *had* been under the impression that the Ford ... Jul 3 2015, 08:08 PM
Mark Henry
To be clear, my car's problem is that at high... Jul 3 2015, 10:33 PM
ThePaintedMan I've often heard them used synonymously, so co... Jul 4 2015, 07:28 AM
Kansas 914
I've often heard them used synonymously, so c... Jul 4 2015, 07:32 AM
JDW914
[quote name='ThePaintedMan' post='2205963' date='... Jul 4 2015, 09:11 AM
Mark Henry
I've often heard them used synonymously, so c... Jul 4 2015, 09:51 AM
stugray
I've often heard them used synonymously, so c... Jul 4 2015, 10:34 AM
Kansas 914
So once you install the Ford relay the system wo... Jul 4 2015, 11:00 AM
Jeffs9146
I've often heard them used synonymously, so ... Feb 17 2016, 10:53 AM
HalfMoon Local parts stores emplyee's often won"t ... Jul 4 2015, 09:53 AM
Mark Henry
Local parts stores emplyee's often won"t... Jul 4 2015, 10:07 AM
ThePaintedMan LOL, thanks for clarifying that Mark and Stu! ... Jul 4 2015, 05:46 PM
NFBrown I've been wondering why once in a while I get ... Jul 4 2015, 06:58 PM
screenguy914 To summarize the various posts on the subject, the... Jul 5 2015, 01:15 PM
Tom The ford solenoid, ( in this case used as a relay ... Jul 6 2015, 03:07 AM
screenguy914
The ford solenoid, ( in this case used as a relay... Jul 7 2015, 03:26 AM
Geezer914 I just did this. I used an SS571 Standard Motor p... Jul 7 2015, 05:56 PM
sean_v8_914 :deadhorse: Feb 17 2016, 11:06 AM
Mark Henry
:deadhorse:
No....it's beating a dead start... Feb 17 2016, 12:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:19 PM |
