Driver Seat moved closer to steering wheel |
J/41 |
Jul 6 2015, 05:57 PM
Newbie Group: Members Posts: 8 Joined: 7-June 15 From: princeton, New Jersey Member No.: 18,815 Region Association: North East States |
[size=7] Hi everyone, I have a '74 2.0 914 that I am putting back together. Please help! Has anyone had to move the driver seat closer then in the original factory position. I need to get the seat closer so my wife can drive the car and I am not sure how to do it. There is a cross peice of the floor pan that is right up against the seat frame. Any and all Ideas would be greatly appreciated...... Mnay thanks, Jo (IMG:style_emoticons/default/unsure.gif) hn |
Ian Stott |
Jul 6 2015, 06:36 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I adjusted the pedals out a bit farther, give that a try before you do anything else, they are designed to do that.
Ian Stott Moncton Canada |
J/41 |
Jul 6 2015, 07:08 PM
I adjusted the pedals out a bit farther, give that a try before you do anything else, they are designed to do that. Ian Stott Moncton Canada Hi Ian, I didn't know the pedals were adjustable..where are the adjustments for the pedals located. I just looked under the seat again and I am pretty sure the seat is up all the way. Howevere Maybe tomorrow I can pull the seat out and take a look. I have had several 911's and never with getting the seat up close enough .. this is my first 914. It should be on the road in the next couple of weeks.. I will start working on the interior soon.. New carpet etc. install a radio lube everything.. thanks for your help John G |
Ian Stott |
Jul 6 2015, 07:26 PM
I adjusted the pedals out a bit farther, give that a try before you do anything else, they are designed to do that. Ian Stott Moncton Canada Hi Ian, I didn't know the pedals were adjustable..where are the adjustments for the pedals located. I just looked under the seat again and I am pretty sure the seat is up all the way. Howevere Maybe tomorrow I can pull the seat out and take a look. I have had several 911's and never with getting the seat up close enough .. this is my first 914. It should be on the road in the next couple of weeks.. I will start working on the interior soon.. New carpet etc. install a radio lube everything.. thanks for your help John G The pedals themselves are adjustable, get right down to the pedal cluster and you will see the bolt to back off. I was surprised at what a difference it made, my daughter is 5 foot 1 and she can drive it no problem. Ian |
J/41 |
Jul 6 2015, 07:35 PM
I adjusted the pedals out a bit farther, give that a try before you do anything else, they are designed to do that. Ian Stott Moncton Canada Hi Ian, I didn't know the pedals were adjustable..where are the adjustments for the pedals located. I just looked under the seat again and I am pretty sure the seat is up all the way. Howevere Maybe tomorrow I can pull the seat out and take a look. I have had several 911's and never with getting the seat up close enough .. this is my first 914. It should be on the road in the next couple of weeks.. I will start working on the interior soon.. New carpet etc. install a radio lube everything.. thanks for your help John G Thanks again...I will try that tomorrow Too! jg The pedals themselves are adjustable, get right down to the pedal cluster and you will see the bolt to back off. I was surprised at what a difference it made, my daughter is 5 foot 1 and she can drive it no problem. Ian |
bdstone914 |
Jul 6 2015, 09:56 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I adjusted the pedals out a bit farther, give that a try before you do anything else, they are designed to do that. Ian Stott Moncton Canada Hi Ian, I didn't know the pedals were adjustable..where are the adjustments for the pedals located. I just looked under the seat again and I am pretty sure the seat is up all the way. Howevere Maybe tomorrow I can pull the seat out and take a look. I have had several 911's and never with getting the seat up close enough .. this is my first 914. It should be on the road in the next couple of weeks.. I will start working on the interior soon.. New carpet etc. install a radio lube everything.. thanks for your help John G The only adjustment on the pedals is a slight amount on the clutch pedal. You might get 1/2 adjustment. You could make thick pedal covers for the gas brake and clutch pedals. If you wanted to do something semi permanent I have extra brake and clutch pedals that could be used to fab up adjustable height pedals. I have some ideas on how that could be done. Or you could get another seat frame and graft on longer rails. Bruce Thanks again...I will try that tomorrow Too! jg The pedals themselves are adjustable, get right down to the pedal cluster and you will see the bolt to back off. I was surprised at what a difference it made, my daughter is 5 foot 1 and she can drive it no problem. Ian |
Lo-Fi Version | Time is now: 1st June 2024 - 10:33 AM |
