Installing a 3.2 or 3.0 Engine... |
Biggles |
Jul 8 2015, 01:09 PM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Hi All
looking for some advice from those members who have installed either a 3.2 Carrera or 3.0 SC engine. Trying to gather information for my conversion but the consensus of opinion is one of the following: 3.2 Carrera standard engine with 40 IDA3 Webers - will they bolt on and how much adaption work to the manifold is required? Heard the port sizes are vastly different ? 915 magnesium case gearbox with a aftermarket gearbox mount - is Patrick MS the only one who does this? SC flywheel required to suit 915 box? 3.0 SC engine standard engine with 40 IDA3 Webers - should bolt straight on with no port adjustments? 915 mag case as above or early 911/01 gearbox with standard 914/6 rear mount. intermediate late required for 911 gearbox ? I definitely want to go the route of 40 IDA Webers but don't want to track the car, so not looking for top end speed just low to mid-range. What chokes have people put in for this application and how does it drive ? Sorry, lots of questions ! thanks Chris |
Biggles |
Jul 9 2015, 07:34 AM
Thanks all for the comments. Interesting to read experiences.
The reason for carbs is simply that I like the way they make the car drive. Yes can be more fussy when cold but properly set up, I don't see an issue. It's what I am used to in other cars. The problem is matching everything up correctly. Has anyone put 40s on a 3.2 or is it a big no no? With standard cams and pistons will webers work (with obvious set up) on either a 3.0or 3.2? Interesting about mechanical advance problem but sure that can be solved |
Mark Henry |
Jul 9 2015, 07:40 AM
The problem is matching everything up correctly. Has anyone put 40s on a 3.2 or is it a big no no? With standard cams and pistons will webers work (with obvious set up) on either a 3.0or 3.2? 40's will be fine on a stock 3.0 or 3.2 still only 500-533/cc per cylinder. But for a stock 3.2 you can't beat the factory FI |
Lo-Fi Version | Time is now: 7th June 2024 - 05:13 PM |
