Electric Avenue is Bright, Finishing the ABM Electrics |
EdwardBlume |
Jun 13 2015, 01:40 AM
I tested the battery tonight and its putting out a charge. The ABM from what I can tell, has a new engine harness, MSD, JWest fuse panel, a blasted interior, H4s with relays, and a newerish stock board.
With nothing "on", hooking up the battery seems to "arc" the front headlight motors, or something up front. Transmission ground is on, battery (-) is ground, front turn signal grounds are attached. Nothing at the ignition, although with light switch "on" no "arc" but no light. Ignition switch seems loose. Wiper handle is very loose. I bought a color diagram, but I'm color blind. Is there a method to trace electricity step by step from the battery out through the harness, into the dash, and out to the lights? I need to get this ABM on the road! |
JeffBowlsby |
Jun 17 2015, 03:04 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Here is my unfused circuits list for a 1974 914.
Attached image(s) |
EdwardBlume |
Jul 13 2015, 11:02 PM
JeffBowlsby |
Jul 13 2015, 11:16 PM
Here is my unfused circuits list for a 1974 914. If there are unfused circuits, does that mean there will be power drawn for testing for shorts.. i.e. the clock? Nope. Clock is on Fuse 11. You have a factory wiring schematic and know how to read it right? |
EdwardBlume |
Jul 13 2015, 11:58 PM
Here is my unfused circuits list for a 1974 914. If there are unfused circuits, does that mean there will be power drawn for testing for shorts.. i.e. the clock? Nope. Clock is on Fuse 11. You have a factory wiring schematic and know how to read it right? Yes, thanks. I got the color laminated one. Just not in front of me right now. I'll post picts of the stray wires to see if the right places can be attached. |
Lo-Fi Version | Time is now: 7th June 2024 - 04:03 AM |
